It is currently Wed Jul 23, 2025 7:14 pm
PostPosted: Sat Apr 21, 2007 6:50 pm
Brian poped around today and asked about getting oil pressure up
if it takes 20 secs stop and prime the pump.
if no oil after 20 secs.
wind with plugs out
Loosen the cooler pipe off the block, sometimes they get air lock there.
Just some additional info for you mate :wink:
PostPosted: Sat Apr 21, 2007 6:54 pm
I packed my oil pump with vasoline.. Wound it over with the plugs out and got oil pressure pretty quick. Then had to run the cam in once it started.
PostPosted: Sat Apr 21, 2007 6:58 pm
Yep packing the Oil pump with Vassos is a good idea as it does not drain out on instalation :wink:
PostPosted: Sat Apr 21, 2007 7:05 pm
Online
You can also use cam lube, it's pretty thick and won't drain off in a hurry.
PostPosted: Sat Apr 21, 2007 7:17 pm
Yer thats what I used and so did Brian
Users browsing this forum: drmini in aust and 98 guests
