It is currently Sun Jul 27, 2025 10:22 pm
PostPosted: Mon Apr 23, 2007 10:46 pm
:shock: :shock: :shock: driving home tonite pulled into the servo and filled up, drove out of the servo drivin normal went to change to 2nd gear jus like normal clutch fully depressed smoothly went to pull into second gear and it crunched and shook the car and wouldnt go into 2nd....meanwhile me sh!ting my pants quickly put it in neutral and selected 4th gear and luckily i was close to my mums bf's mechanic shop so dropped the car off there.... this was extremely weird as second gear has always been very smooth and no problems!!!! ONLY REBUILT THE ENGINE AND GEARBOX JUST OVER A YEAR AGO!!!!! :evil: :evil:
any ideas as to what has gone wrong??
1992 Toyota Starlet GT EP82
PostPosted: Mon Apr 23, 2007 11:55 pm
linkage problem??
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Apr 23, 2007 11:58 pm
can the gear box be taken out without the engine being taken out, or must the engine also come out?
PostPosted: Tue Apr 24, 2007 1:00 am
they both must come out to take gbox of :(
PostPosted: Tue Apr 24, 2007 8:38 am
i had a similar thing just last week, but i lost 2nd and 3rd and then gradually 1st and 4th and reverse starting playing up. havent taken it apart yet but i suspect linkages.
PostPosted: Tue Apr 24, 2007 8:53 am
ausmini mod
ausmini mod
Mate, if its crunched and couldnt get in, and it was sudden, you may have a broken Baulk ring (synchro) that happened to mine... fully rebuilt brand new box...
Peter
PostPosted: Tue Apr 24, 2007 7:16 pm
well today was a long day, had uni this mornin and then spent 4.5hrs pulling bits and pieces off my engine in order to pull the engine out on thursday. so far however, when draining the oil this was sticking to the magnet on the sump plug :shock:
looks to me like a tooth off a gear, not to mention all the other fragments on the magnet.
here is the engine ready to be pulled out
now is the eager wait for thursday to see the damage :cry:
PostPosted: Tue Apr 24, 2007 7:27 pm
I reckon you've stripped 2nd gear, and/or the cluster gear..
I'd make sure the rest of the box is all good when you rebuild it.
I did up an S box for a certain person on this forum, had same problem- and it was missing the needle roller bearing off the mainshaft nose! :shock:
PostPosted: Fri Apr 27, 2007 10:04 pm
He don't you have this for sale? The ad says that the engine and box was rebuilt 4000 K's ago?
What do you reckon caused the gearbox to let go so quickly after a rebuild?
You might need to update that ad eh or take it down for the moment?
PostPosted: Fri Apr 27, 2007 10:11 pm
my bad lol mistake on my behalf, i dont think it was done properly first time, was rushed a bit.
Users browsing this forum: fuzzy-hair-man, TartanRed and 110 guests
