It is currently Wed Aug 06, 2025 7:45 pm
PostPosted: Sat Apr 21, 2007 5:53 pm
Knox auto carpets also do stuff for mini's
Try
http://www.knoxautocarpets.com.au/
(\_/)
(O.o) <CoPy> <) MaY oBtAiN wOrLd DoMiNaTiOn.
PostPosted: Tue Apr 24, 2007 4:18 pm
Can someone tell me how to fit the 9 piece set? I dont know how to fit the wheel arch carpets and the rectangular looking piece (is it for under theheater?) thanks
 Post subject: Carpet
PostPosted: Tue Apr 24, 2007 5:22 pm
the rectangular piece goes behind the heater you have to take the heater out. the wheel arch piece's should just sit there when you put the hole lot together, also i used the door strap to hold mine in place .
Steve
Classic Not Plastic
PostPosted: Tue Apr 24, 2007 6:19 pm
Screw that, Im not taking out my heater again. Ill just cut it up. Any tips on cutting the front bit where the steering wheel and gear lever hole is?
PostPosted: Tue Apr 24, 2007 6:27 pm
Start with the smallest hole, get bigger once you know it fits or need to shift the hole center one way or the other.
PostPosted: Tue Apr 24, 2007 6:36 pm
What about the little pieces what are they for? I got 2 of them, trapezium type shape
PostPosted: Tue Apr 24, 2007 7:03 pm
They go at the end of the floor cross member, between the seat and the door frame to cover up that bit of metal.
 Post subject: carpet
PostPosted: Tue Apr 24, 2007 7:05 pm
They go over the box section where the seat bolts on.
Steve
Classic Not Plastic
PostPosted: Wed Apr 25, 2007 2:43 pm
With the clubman gear sticks and rubber covers, does the cover go under the carpet, and the metal brace ontop, or both rubber and brace go over the carpet, so you can see it?
Please make a quick reply thanks
PostPosted: Wed Apr 25, 2007 4:15 pm
Give Ash some flowers Nick .
My deluxe has the rubber boot on top of the carpet. CBF putting it underneath the carpet when I replaced it. The metal retainer thing goes on top of the rubber gaiter.
So mine is (from the bottom) carpet, rubber gaiter, metal retainer.
This way bits of the carpet can't poke through under the metal retainer.
PostPosted: Wed Apr 25, 2007 4:19 pm
It's up to you how you want to put it.But i put the carpet under the rubber and brace, it also hide's the carpet edge were you cut it.just in case you don't cut it very neat.
Steve
Classic Not Plastic
PostPosted: Wed Apr 25, 2007 4:40 pm
if you think about the way it should be, the rubber boot should go underneath the metal, followed by carpet and then the metal trim. otherwise it gives the chance that if water splashes up around the gear selector, it'll wet the carpet and linger around.
but it wouldnt be british if it was done properly :lol:
PostPosted: Wed Apr 25, 2007 5:01 pm
Thanks boys, my dad insisted it to be like it was (rubber above the carpet) so i went along with it. ALthough it would look neater the other way, i cant be stuffed changing it now, as my seats are in :D
PostPosted: Wed Apr 25, 2007 7:40 pm
Also people wiht the 9 piece set, what did you do for the seatrests? Did u just leave it rubbing against the new carpet or make a plastic slider like original carpets?
PostPosted: Wed Apr 25, 2007 11:30 pm
Die Die Die!!
buy bigger rear foot matts ?
Users browsing this forum: No registered users and 32 guests
