It is currently Thu Aug 21, 2025 10:16 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Tue Apr 24, 2007 8:41 pm
Yep the 1.75 will be ok but just get the needle size right and they work good.check code on the needle in carb fit carb to engine and see how it goes if it runs too rich check out a web site called mintylamb.com.you can go to a graph type your needle code in and then compair it to four other needles at the same time remember you need to go to the 100 thou jet graph not the 90 thou jet graph for 1.75 carbs
Users browsing this forum: No registered users and 259 guests
