It is currently Wed Jul 23, 2025 10:51 pm
PostPosted: Thu Apr 26, 2007 10:12 pm
Looking at that intercooler again, it looks very Nissan S13? Wats it off?
PostPosted: Thu Apr 26, 2007 10:56 pm
that's the skyline one i gave you, isn't it?
PostPosted: Fri Apr 27, 2007 11:57 am
Give Ash some flowers Nick .
Looks good, looks heaps neater than sticking the intercooler at the front.
PostPosted: Tue Jul 24, 2007 1:34 pm
ok just thought i would giev yo uan update.
the intercooler and the ignition system is pretty much finilised, i have a dyno session coming up in a week or just over and this should see the tune 100% spot on if not very very close to it.
i took the car for a drive on the weekend after playing carbie springs and stuff and thought i should take some air intake temp readings now that the intercooler was finished.
now some of you may remember that before i fitted the intercooler the air intake temp on a 25 degree day would see around 110 to 115 degrees on 13 or so psi.
well the temp on sunday was only around 17 degrees or so but still on 16psi the air intake temp never went above 32 degrees, this is a drop of around 80 degrees, i am blown away that it so efficient given its location.
i am very happy with it and i think it looks good too.
Grant.
100% Pure A Series Turbo
PostPosted: Tue Jul 24, 2007 1:56 pm
so r u still going to make the night at the drags on the 8th august?
PostPosted: Tue Jul 24, 2007 4:34 pm
you betcha, thats why its booked in for the Dyno session.
Grant
PostPosted: Tue Jul 24, 2007 4:48 pm
Brilliant results with lowering temps!
 Post subject: Airflow?
PostPosted: Thu Nov 22, 2007 10:04 am
Sorry to bring this thread back but ...
How are you getting air flow to the intercooler? Ideally you need come kind of air splitter to force air onto it otherwise it will just be absorbing heat from within the engine bay and cooled a little by the normal airflow through the front grill.
-Alan
-Alan
 Post subject: Re: Airflow?
PostPosted: Fri Nov 23, 2007 7:25 am
-Alan
i have now made but not installed a alloy ducting which directs air from the grill through it, but think about it if your cooling system works well enough then an ic will work fine as it has less restriction around it (shroud etc) but yes it does not have a fan but its not needed, my results of the air temp decrease is proof it is getting good airflow back out through the guard.
PostPosted: Fri Nov 23, 2007 8:53 am
Grant,
That's not a good temperature drop, that's a phenominal temperature drop!
Like 70%!
I am amazed it was this high!
Trucky
PostPosted: Fri Nov 23, 2007 9:20 am
mmmm.....not sure it's as grand as it initially sounds (don't get me wrong it's still good). Before the cooler was on your intake was about 4.5 ambient, now it's running at just under 2. So saying a 50-60% decrease is better than saying 80 degrees.
So that's an air/air cooler? Excuse my ingnorance! :oops:
PostPosted: Fri Nov 23, 2007 9:50 am
A fan for the intercooler is not really necessary, but if you can get a shroud to force air into the intercooler core, the efficiency will be alot better.
That alloy ducting sounds spot on. It should drop the temps even further :D
-Alan
