It is currently Wed Jul 23, 2025 8:05 pm
 Post subject: paint tips
PostPosted: Fri Apr 27, 2007 6:25 pm
hey guys
so ive welded in the sills, fill welded in all the little tiny cracks of rust and bogged over, some pannels i thought i would have to replace but just full of bog to match the difference in height, now that the entire car is rubbed back on tuesday im going to paint the car with 2 coats of undercoat and 4 colour, is there any tips anyone can give me, i dont care if i have heard them before its the fact i have nt painted a car by myself.
PostPosted: Fri Apr 27, 2007 8:40 pm
One coat of undercoat, two of spray putty, two top coats and maybe a clear coat. Sand in between coats. Also a search on here will give better tips and the paint types to use.
Wear disposable overalls and a decent mask - not one that comes in a box of 10. :lol:
Michael N
PostPosted: Sat Apr 28, 2007 1:19 am
depends where and what u are using mate..
acrylic..
two pack...
best advice i can give is boardfiel it, make sure its straight, frimer, wetrub witha block and move it around constantly, so u dont get any small ridges
teh better prep u do the better the paint will be..
with the wet rub thing, i could see my reflection in the primer, no distortion either 8)
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sat Apr 28, 2007 9:29 am
spay putty, im gonna look for it, do you need a huge nozle for that or would normal sizes be alright,
its just going acrylic white, its only to pass blue slip, after that i will go a bit more creative with the paint.
maybe some pin stripping to make it look like some ownes it.
PostPosted: Sat Apr 28, 2007 11:53 am
acrylic should be easy mate.
just good prep is alll i can say
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
Users browsing this forum: Bing [Bot] and 96 guests
