It is currently Sat Jul 19, 2025 12:25 am
 Post subject: Question about Radiators
PostPosted: Sat Apr 28, 2007 11:10 pm
My car stinks when I have driven it for a while, like stinky hot smell. :shock:
I've changed the oil and just had new brakes (thinking it might be the new brakes being stinky :?: )
I topped up the coolant tonight and see it's very froffy and with the radiator cap off steam/smoke is coming out of the radiator.
Reckon I should have the radiator flushed? Or could it be more problems?
Not sure when radiator was last cleaned out???? :?
1979 Leyland Moke (which is for sale)
PostPosted: Sat Apr 28, 2007 11:13 pm
probably your new brakes
PostPosted: Sat Apr 28, 2007 11:17 pm
Get the radiator flushed
and get someone to do a head gasket leak test
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Sat Apr 28, 2007 11:28 pm
I'll see how it goes tomorrow on the Mini run to Lorne, and get all the mentioned things checked next week. I would be happy to have the cooling system checked anyway with it being a new addition to my fleet and all, I'd like to know what has been done and what needs to be done.
:D
PostPosted: Sat Apr 28, 2007 11:44 pm
you may have a couple of issues here, but definitely, the radiator bit doesn't sound right at all. Smell may not be related to that but then again quite well could be.
PostPosted: Sun Apr 29, 2007 12:57 am
I'm not a mechanic but if you have a heater could it be a leak from the heater core inside the car which might be why you can smell it? Just a thought!
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Sun Apr 29, 2007 9:30 am
My first mini blew a head gasket and threw a couple of welsh plugs. The engine cooked each time but it made funny sounds more than smell.
I would say your brakes are not adjusted properly (if they are drums) if you have a smell there all the time.
Daniel
PostPosted: Sun Apr 29, 2007 10:41 pm
How old is the exhaust? New paint burning off? Any greasy hand prints on it?
Any greasy hand prints on the brake drums?
How long ago was the engine cleaned/degeased, with what, and how well was it rinsed?
PostPosted: Mon Apr 30, 2007 10:48 am
Engine has lots of oils and crap on it. The smell has started to go away, a run to geelong helped and I changed the oil over the weekend too.
I will clean the engine this week, and have the radiator looked at too.
Thanks one and all. :D
