It is currently Mon Jul 21, 2025 8:30 pm
which car would suit towing the mini
hulix 2.6 non turbo deisel 94%  94%  [ 15 ]
commadore 3.8lt not as healthy as it was a while ago 6%  6%  [ 1 ]
Total votes : 16
 Post subject: car to tow the mini
PostPosted: Sun Apr 29, 2007 12:19 pm
so in half hour i need to choose a car to tow the mini on a trailer,
89 hulix 2.6 n/a deisel
or
94 berlina 3.8 with a smokey cylinder
PostPosted: Sun Apr 29, 2007 12:21 pm
I is a mookenik
go with the hilux man they a built to take a load on the back im sure its solid enough to take a mini, dont risk with a smokey cylinder
PostPosted: Sun Apr 29, 2007 2:10 pm
High heel ninja
Well you know the cars, so you should be in the best position to chose, they both should do the job.
Why would you put a poll on this? seems silly to me!
Doogie
PostPosted: Sun Apr 29, 2007 2:26 pm
i prefer towing minis with minis... but mostly i use my 1.4L barina to tow the car trailer
- '74 Clubman Ute project
PostPosted: Sun Apr 29, 2007 5:14 pm
are u serious i dont think that would be totally legal?
PostPosted: Sun Apr 29, 2007 5:39 pm
hilux's are great, i almost got one recently for a similar reason, and i like toyota's
PostPosted: Sun Apr 29, 2007 5:48 pm
im goin the toyota too but the aristo 8)
PostPosted: Sun Apr 29, 2007 8:38 pm
Way to talk up the Commadore :lol:
0 votes for it so far - I think you had your answer before you asked it!
PostPosted: Sun Apr 29, 2007 8:51 pm
Anything will tow a Mini so I would go with the car that will be more usefull for everything else as well. A Hilux will be cramped and uncomfortable on a long trip. A Commodore will drive you crazy with oil leaks and rattles. Get a Magna. They will tow a Mini and they will be comfortable on a trip while being fairly economical around town (better than a Commodore or Hilux)
A mate works for a fleet company and he sells ex-lease Magnas for about $7,000 for a 2001 model. You can pick up earlier ones even cheaper.
PostPosted: Sun Apr 29, 2007 9:31 pm
A MAGNA?!?! oh i feel sick... magna would probably break down before it would get to the mini.. haha just havn a go :P
this is what im talkn about... but only in WA :)
PostPosted: Sun Apr 29, 2007 10:24 pm
wow thats awesome
i thought minis are only rated to tow 350kg :lol:
PostPosted: Mon Apr 30, 2007 1:05 am
the ute is rather low 8)
i tow mini all the time with my commodore, and otehr cars, valiants corolla,...
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Apr 30, 2007 7:50 am
jesus, towing that trailer with a mini on it. sir i take my hat off to you, you have balls
PostPosted: Mon Apr 30, 2007 7:54 am
:shock: Are there any over-ride brakes on the trailer ??? It's not a matter of being able to tow the weight , it's being able to stop the weight from overtaking you on the road or under braking . Even with good brakes on the trailer I'd only be inclined to tow that out of the yard and up the road a bit for the photo as it's a lot of weight pushing on the mini ute (even if the van hasn't got an engine in it ...)
Back to the original question , I say the hilux because I've done most of my towing with a full chassis'd ute and prefer it to a sedan . the non turbo diesel might be a bit slow on any hills you had to go up but it'd do the job . Which did you use and how did it go ?
PostPosted: Mon Apr 30, 2007 10:02 am
I have a commodore (VN) and its entirely unsuitable in its unmodified form for towing car trailers.
Firstly, they have a coil spring rear and the coil springs don't compress evenly and consistantly. The coils tend to bow out which means it sticks the bum of the car right down and the nose right up. To the point where the front brakes lock up unnecessarily. Its also bad with night driving because of the nose up, with headlights.
Secondly, the 3.8 ltr motor has heaps of grunt when its just pulling the car but lacks the torque when you put a load on it. If the commodore has the T700 four speed auto you will also find that unless you lock it into a lower gear, it will actually accelerate down hillls even with the foot off the go pedal.
Thirdly, Getting the mini (or any car) is hard to get on and off the trailer because the rear of the trailer is higher at the rear - lots of exhausts scraped or continually looking for a bank to back the trailer against.
Go for the hider riding, better geared solid chassis.
Users browsing this forum: timmy201 and 84 guests
