It is currently Wed Jul 23, 2025 12:42 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue May 01, 2007 4:14 pm
alsminik wrote:
my tank was given to me and i fitted it straight away but still forget to put petrol in either of them :oops:
Keep them full :!:
They are not painted on the inside - the petrol is the only thing that keeps them from rusting.
PostPosted: Tue May 01, 2007 4:38 pm
lets not forget with twin tanks not olny do you double the capacity but you get a better balance of weight over the wheels.
PostPosted: Tue May 01, 2007 5:09 pm
but only when there is nobody in the drivers seat.
PostPosted: Tue May 01, 2007 5:12 pm
you are a wealth of knowledge bloke how do you do it for the money :?: :?: :?: :?: :?:
PostPosted: Tue May 01, 2007 5:17 pm
it was serious comment. Twin tanks only balance an empty car, if you put a driver in it and you have twin tanks the car is actually less balanced.
PostPosted: Tue May 01, 2007 6:29 pm
It would balance there rear I guess.
That's not the point though. It doubles your fuel capacity. Both my mini's (well nots actually mine.....) have twin and it's great, especially in that I live a fair way from any real fuel station. If I wanted more range I would would be a rover long range tank and run both but no need really. And my RHD tank only cost $150. The first time I went to a hotbricks meeting I said a I needed one and I was offered one for $150, so I said "yeah ok."
I wouldnt pay that for a LHD one though.....
PostPosted: Thu May 03, 2007 12:45 am
So is the basic feeling that the tanks aren't really in demand at the moment?
Thanks Wombat, I spoke to Paul, who said that he was finishing off his moulder and that he wasn't sure exactly when it would be ready. He said that he would be after $500 for the tank and fitting kit. I was hoping to get them made for a little less than that. But dont know whether i could sell enough of them to make it worth while.
Regarding the tank without filler neck, without any previous knowledge on how quickly the tanks level, do you usually pour fuel from both sides - ie. fill one side and then fill the other? Or does the fuel flow pretty quickly? I'm not sure a breather would be the best idea as you'll get fuel smell all through your interior. Would you really need one? what would its purpose be - to not create a vaccum i suppose, what about two lines - one at the top and one at the bottom?
PostPosted: Thu May 03, 2007 1:27 am
Miniboy, It takes about 10 minutes for the tanks to level out! You definitly have to fill both at the servo, If I just fill the l/h, the guage shows full initially, then a while down the road the tanks balance, and you only have 1/2 showing on the gauge!
As was said, the balance pipe is only small, 1/4" internal bore I think!
Graham
Sir Alec! we are not worthy!
PostPosted: Thu May 03, 2007 6:49 am
there's an excellent stonie cartoon in one of the mini experiences that describes the procedure... :)
PostPosted: Thu May 03, 2007 7:03 am
He He! there is too! he nips from tank to tank "just adrop more in 'ere", then "a bit more this side" .........repeat etc! :lol: :lol:
PostPosted: Thu May 03, 2007 8:41 am
Hence the need for a large balance pipe if wanting to only fill from one tank!!
But it would also need the left tank outlet to be enlarged.
Hmmm, All seems to be a lot of work.
Wouldn't even go close to paying $500 for a plastic tank with fitting kit. I can get a genuine tank (2 hand) and new fitting kit for less.... Anyway, I suppose Paul knows what he is doing.... :roll: :roll:
Yep breather needed for a vacuum preventative, and probably best to run it over to the other tank, so more mods.
Good idea tho.
PostPosted: Thu May 03, 2007 9:01 am
i think most people have had the "making new right hand tanks" idea. i had one of mine slip open and was going to make a mould....etc etc
in the end the cost to make one would be too high, and then people wouldnt buy them because most people are waiting for a bargain etc etc.
my next project is making plastic shrouds for under the rear wheel archs and the front wings to stop stone chips and road scum. in the uk they go for 65 pounds just for the front. rip off
PostPosted: Thu May 03, 2007 11:09 am
I run a large LS type tank on the left & a cooper "S" r/h tank ,,, & if i go on long trips i will also take a 10litre jerry can as well
with the "balance the car" thing, if there was only the driver in the car, then with the the battery on the right & the right hand fuel tank will out weigh the drivers side & the left side would be light
but a few spares & tools, bottle of water & oil & brake fluid strategically placed can help balance it nicely
But that`s just what i do, doesn`t mean that everyone should do it
I`m having a good friend of mine (Dale) fab me up a long range alloy tank for the boot of the fastback Monaco mini , with the twin cam 16v turbo engine in it will surely need some extra fuel for all the long trips to hay etc :-)
PostPosted: Thu May 03, 2007 12:58 pm
"Long range" tanks aren't big enough! :lol:
Well my theory was that they would be cheaper than buying a genuine RH tank if in plastic. Obviously I was mistaken. :?
PostPosted: Thu May 03, 2007 1:28 pm
On the fill up procedure, I fill up the right then the left (no reason why you couldnt park on the other side and do it the other way) and that's fine.
I used to fill up the right go fill the left go back and top up the right but it really wasn't worth it, the rate at which they cross feed is very minimal. As said above about 10 minutes would probably be close.
My thinking is that with my car using more fuel that a stock one (More air + more fuel = more power) you would want/need another tank. Also it allows me to get fuel once a week on the cheapest day rather than twice a week with a single tank. I fill up usally when it hits 1/2 way, in a single tan kthat would be empty, need to fill up before it's empty!
Users browsing this forum: 1071 S and 78 guests
