It is currently Tue Jul 29, 2025 3:04 pm
 Post subject: RIP Henry
PostPosted: Wed May 02, 2007 8:12 pm
Gday all - well a sad day here as Henry, my every faithful '77 Clubby, finally shat the biscuit. Driving home yesterday afternoon noticed a low down rattle in the motor. Got home and put him out the back and the rattle had become a rumble and then he expired with a wheeze and a knock - knock. Whipped the engine out in 3 parts(head, then block and finally the box - no engine hoist!!!)but knew right away by the smell of the fumes coming from the oil cap before I had even started. Spun the bearings on number 1 rod and now forces me to finally do that restoration I have been putting off for 18 months.
To his credit, he had just ticked over 286,935km on the original engine and the rest of him looks pretty good considering these high miles. Now I have a spare engine to rebuild and keep tucked away for next time. Proves with some TLC these little beasts will last a very long time but thank god he didnt pass away while I was miles from home.
Anyeways I will definitely not be showing on Saturday for the Dyno run but may still come up in the Soob for the day - depends on how depressed I get...lol
Having a beer now in memory of him and toasting his return in a couple of months. Got the paint, new engine is all ready and the new subs are already to go. We can rebuild him.
Here are some pics of the offending bearing
Will post up many more as I progress.
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Wed May 02, 2007 8:22 pm
Geez Rob, that bearing's not too bad!! :lol:
My 1360's centre main job at Wakefield was far, far worse.... :cry:
Good luck with the rebuild. :wink:
PostPosted: Wed May 02, 2007 8:23 pm
That bearing looks like it has done a lot of work but it does not look noisy. :?
Keep looking. :cry:
PostPosted: Wed May 02, 2007 8:25 pm
Keep looking. :cry:
I agree, ping test that crank... :wink:
PostPosted: Wed May 02, 2007 8:34 pm
Well I knew it was this one as there was a loose cap just barely holding it together. Thankfully it did otherwise the box would have been mush as well. The cap could be moved by the hand and very very sloppy side to side movement.
I am now on the second beer and flashing up the heater in the garage - Kev got the stacks today - has the cash arrived there at all??
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Wed May 02, 2007 8:35 pm
PM sent.
PostPosted: Wed May 02, 2007 9:44 pm
Does this mean you will be bringing the Subaru to the Araluen run!? I'm considering putting rego back on the Mini just for the trip, no other vehicles that will go the distance. :lol:
If you need an engine hoist I have one you can borrow if you need it, though I assume you will be putting the engine in with the new subby?
PostPosted: Thu May 03, 2007 9:46 am
Rob
Its been a tough little car, you are just down the road mate so if you need a hand or anything just give a yell mate
Jon
Users browsing this forum: fuzzy-hair-man and 128 guests
