It is currently Wed Jul 16, 2025 1:07 pm
 Post subject: spark plugs
PostPosted: Wed Dec 08, 2004 6:43 pm
hi all,
i'm having a bit of trouble with my spark plugs.
i'm using champion n9y plugs on a 1100 unleaded engine and
the plugs are becoming sooty and engine then does not fire on all 4 cylinders.
once i clean them engine runs like a dream.
am i using the right plugs and is this happening because i don't drive the car often
roll:
PostPosted: Wed Dec 08, 2004 6:49 pm
N9Y should be OK on an 1100, or any near stock Mini.
If sooty, either the mixture is rich or the ignition has a problem. How old are the plug leads, points & dizzy cap?
If all are sooty I'd suspect the carby mixture. :wink:
PostPosted: Wed Dec 08, 2004 6:55 pm
hi dr
yes all plugs were sooty
i'll adjust the mixture tomorrow
note..when i take the car for a long run and remove the plugs there all clean
that what makes me think the soot is from doing short runs or
just idling the car in the garage
thanks
 Post subject: Re: spark plugs
PostPosted: Wed Dec 08, 2004 7:02 pm
mini_me wrote:
hi dr
thanks
Either the carb mixture is set too rich or the float level is too high, I reckon. :wink:
PostPosted: Wed Dec 08, 2004 7:12 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
or he just dont warm it up enuff to run of choke
makka
PostPosted: Wed Dec 08, 2004 8:13 pm
i had this problem
carb needle had bad marks on it
and put new gasket on breather plates (just under manifolds on the back)
now car doesnt turn off anymore,
because of plugs that are really sooty
because of plates that dont suck air no more?
fingers crossed
Inconspicuously Conspicuous
PostPosted: Wed Dec 08, 2004 8:53 pm
I Would go with the Doc.
Carby has to rich of a mixture
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
PostPosted: Thu Dec 09, 2004 7:51 am
Or the wrong needle.. :?
PostPosted: Thu Dec 09, 2004 11:16 am
makka
Is the choke turning off properly?
Chris
Everything I like is either
PostPosted: Thu Dec 09, 2004 6:03 pm
Yeah there's only 800 or so of 'em now- at $20 each, which one is dead right for you? :lol: :shock:
PostPosted: Thu Dec 09, 2004 6:29 pm
Dyno Time..Its just that the plugs are good after a long run and crap after short runs :?
PostPosted: Thu Dec 09, 2004 10:25 pm
Bosch plugs for starters... not NGK or champion :roll:
thats not ur prob... its carby... im running with the "DR" and the boys :lol:
-Cam
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Fri Dec 10, 2004 6:09 am
the doc was right the mixture was way out- too rich-.
i adjusted it by using my colortune spark plug which i
bought years ago for use on my mgb but never used it,
also found qne cylinder not firing due to a shorted spark plug.
thanks again guys
PostPosted: Fri Dec 10, 2004 6:53 am
Thank god for Ausmini, I can only imagine how many of us would have ended up forking out cash to a mechanic if it wasn't for the advice recieved here :D
PostPosted: Fri Dec 10, 2004 6:54 am
Have you had your mini Long
