It is currently Mon Jul 28, 2025 8:06 pm
 Post subject: suspension sagging
PostPosted: Sat May 05, 2007 5:47 pm
I recently hit a potthole causing the passanger side guard to rub. I checked the suspension trumpet and its not broken, just wondering if anyone else has any ideas on what maybe wrong?
cheers :?
PostPosted: Sat May 05, 2007 5:51 pm
High heel ninja
99% thats your suspension cone is RS, basically needs replacing.
Doogie
PostPosted: Sat May 05, 2007 6:11 pm
what is the suspension cone? im not up with heaps of lingo the suspension is dry type. is it easy to replace? does it involve dropping out the sub frame and removing springs as i dont think ive got the tools for that? :?
PostPosted: Sat May 05, 2007 6:39 pm
The 'cone' is basically the spring in a dry suspended mini. It is a round rubber domed block with metal sleeve inserts. This rubber provides suspension in exactly the same way as a spring in other cars.
Removing the cones is not an extremely difficult job and can be just as easily done with the subframes in the car.
Front - Use special tool to take up the suspension travel. Then remove the upper suspension arm, release special tool and remove cone.
Rear - remove either top or bottom shocker mount and allow trailing arm to swing down. Then remove cone
Both may need a bit of persuation after the suspension load is removed as the cones can rust into place.
I have ommited a few steps (removing fuel tank etc.) but the steps are all detailed in the manual.
Good Luck
Mister White Keys
"He who has the most toys, Wins"
1963 Austin Countryman Woody
1964 Morris 850 Van
1967 Austin Countryman
1975 Range Rover 2 Door
2004 Subaru Forester XT
2015 Potts Teardrop Camper
RIP 1990 Citroen BX 16Valve
PostPosted: Sat May 05, 2007 10:50 pm
Chances are the nylon cup (ball joint) in the upper control arm has suffered from the "hit" so I would check that too once you have it apart :idea:
Users browsing this forum: rhaj and 81 guests
