It is currently Sat Aug 02, 2025 12:33 pm
 Post subject: SPIN ON OIL FILTER HEAD
PostPosted: Sun May 06, 2007 12:46 pm
THERE IS A SPIN ON OIL FILTER HEAD ON E BAY.
DOES ANY ONE KNOW IF THIS IS ALL I NEED TO REPLACE
THE OLD CARTRIDGE TYPE ON MY 66 DELUXE,WILL MY
EXISTING OIL PIPE FIT STRAIGHT ONTO THIS HEAD
THANKS
1966 mustang coupe 289 auto
1970 mgb roadster auto
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
http://s160.photobucket.com/albums/t173/1966mini/
PostPosted: Sun May 06, 2007 1:14 pm
Yes it will fit and it is a common upgrade modification.
You will need a filter to engine gasket - a filter obviously, and the correct bolts to bolt it on. They are a different length.
The oil pipe will just bolt up as well but take care. The pipe is very easily bent and kinked and sometimes it is hard to get the existing connections undone without twisting the pipe.
Take time - use penetrating fluid and dont use brute force.
PostPosted: Sun May 06, 2007 1:18 pm
THANKS FOR THE ADVISE MIKE
RGDS FELIX
1970 cooper S mk2
1976 mini S
1964 wolseley 24/80
PostPosted: Sun May 06, 2007 2:20 pm
The 2 studs in the engine block are shorter for a 'spin on' filter head. You will need them too.
PostPosted: Sun May 06, 2007 2:26 pm
No need for pukka short studs, use 2 short bolts and spring washers. :wink:
Users browsing this forum: ken@miniauto and 90 guests
