It is currently Tue Aug 12, 2025 5:10 am
PostPosted: Tue May 08, 2007 5:09 pm
I'm trying to get the pinion from an A+ into an A gearbox, but the bearing retainer is a little is to small, is it possible to fit the retainer from an A+ box into the A box
PostPosted: Tue May 08, 2007 6:51 pm
Have you changed diff ratio? if you are going to a taller diff (ie smaller number like 3.7:1 to a 2.9:1) the pinion will be bigger, you can mill the retainer with a file, or a drum sander on a drill is great.
Users browsing this forum: No registered users and 212 guests
