It is currently Wed Jul 16, 2025 7:38 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri May 11, 2007 10:13 pm
odd wrote:
similar to a Citroen suspention setup?
In some ways yes, but it's not really. Think of it as rubber cone suspension (which it is) with a waterbed inside it.
Drive one that's well set up, for road use in a daily driver, they are hard to beat. The ride is superb compared to the rubber cone Mini's buckboard ride.
I drove our dry car 2000Km round Tassie last year. Kept thinking- "should have taken the hydro instead". :x
PostPosted: Sat May 12, 2007 9:46 am
BMC's hydrolastic setup is sort of like a 'static' version of Citroen's hydropneumetics. While pressure in the Citroen system is actively maintained by a hydraulic pump (and also runs the brakes, steering and often the gearchange), the BMC version is set to a pressure and sealed.
I've often wondered how difficult it would be to use Citroen suspension spheres and cylinders in place of a Minis hydro bags. There was a Mini 'prime mover' in MiniWorld years ago that had a full Citroen ride-levelling setup. . .but I'm more talking about setting up each corner sealed and independent and just varying the gas pressure in the suspension spheres to set the stiffness. Bleeding air out of the fluid half of the sphere would probably be a problem, though. . .
Enough musing!!
One for the future. . .maybe. . .
PostPosted: Mon Jun 04, 2007 12:45 pm
Enough musing!!
Sorry to dig up old posts, but is this the Kinetic suspension system that was banned from WRC?
Howard: "You don't need a pen to be a writer Vince"
Vince: "I think you do"
PostPosted: Mon Jun 04, 2007 6:16 pm
IMHO
Mini is too light for benefits of Hydropneumatic suspension. One indication is the low preassure the BMC Hydrolastic systems operates at.
Hydropneumatic runs at 2600psi to create the suppleness linked with high preassure nitrogen and rubber diaphrams.
Austin 1800 on the other hand would have been better on a a citroen style Hydropneumatic system.
:? 8)
Shoot me down in flames on this one if you like.
