It is currently Tue Aug 19, 2025 12:00 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Sat May 12, 2007 5:58 pm
I run Mobil 8000 (98 octane) it is a yellowish colour.
Oh really...hmmmm..I hope thats not a red herring for me. But after the draing the problem went away (for a while).
Anyway..I think it's time for someone who knoews more than me. Mechanic me thinks :(
Dave
 Post subject: Re: Yeller
PostPosted: Sat May 12, 2007 6:54 pm
junglemaster wrote:
9YaTaH wrote:
the new fuel may have found a pocket of the old stuff and is tainted again...but unlikely.
The crap running has probably burn't your points ...have a look there and pull the plugs as well.
Old stuff: possible...which is why I only put 5L back in (in case I need to drain again. Maybe i'll do that tomorrow morning!
Points/Plugs: I pulled the plugs which look "ok"..gave them a cleanup and made no difference. Not really sure what I am looking for at the points end of things.
Dave
More than likely it will be your points, burnt/blackness...number one cause of Mini electrickcal problems. If the points are blackened or closed up when you rotate the engine thats probably your...ergh..problem.
PostPosted: Sun May 13, 2007 9:03 am
Yeah so is Shell VPower.. Sounds like some sort of 98 octane to me..
Andrew
PostPosted: Sun May 13, 2007 9:18 am
diesel is yellow
PostPosted: Sun May 13, 2007 10:15 am
xplosion77 wrote:
diesel is yellow
I did NOT put diesel in it :)
So maybe just a high-octane fuel? That shouldn't hurt the Mini. Maybe they did something else to the car? But why would it behave after draining the tank (for a while). Because the engine was hot?
So the question might be; in what circumstances would it misfire/lumpy when cold/warm but then run fine hot?
Dave
PostPosted: Sun May 13, 2007 10:53 am
I just went and had a look in my Moke's tank, premium unleaded is definitely yellow. I run my moke on premium, but thats only when I can't get ultra-premium, which is also yellow. It won't hurt your mini, its what you should be using (unless you have a Rover maybe?)
My Moke always plays up when its cold, runs quite well once its warmed up though :wink: Its better on ultra-premium but still coughs a bit when its cold.
 Post subject: fuel
PostPosted: Sun May 13, 2007 11:00 am
yer ive seen a couple of different fuels that are yellow.
i like to drive on rails
Users browsing this forum: No registered users and 303 guests
