It is currently Sun Aug 17, 2025 9:50 am
PostPosted: Sun May 13, 2007 6:08 pm
I is a mookenik
nice lol juz a quick question where is the starter solenoid in the minis, ive tryed the wire back but i loose it under the guards
PostPosted: Sun May 13, 2007 6:19 pm
Man i dunno if i wanna be giving u advice with electrical stuff.... its harder then mechanical stuff, which u seem to already have dramas with.... and this can easily cause fires or at least melt wiring.
Why is ur starter wiring underneath ur guards anyway? If u cant find ur starter solenoid, ur not looking hard enough.
If u still have the standard starter, there will be a thick power lead about 30cm long running from the starter to the solenoid, this is where the battery 12v also connects to the rest of the car. Its pretty obvious.
PostPosted: Sun May 13, 2007 6:39 pm
I is a mookenik
yeah i know that like i said but i loose the wires under the guard so i dont know where it is
PostPosted: Sun May 13, 2007 7:43 pm
Why are u chasing wires for the starter? I thought u had an alternator fault?
PostPosted: Sun May 13, 2007 10:12 pm
I is a mookenik
yeah i looked in the mini book i got and it has a wiring diagram in it and according to the diagram it goes from the alternator to the starter to the battery, thats why im thinking wtf, other wise my other question is where is the regulator
PostPosted: Sun May 13, 2007 11:10 pm
Joe , just confirm that Tiny doesn't have a push button starter on the floor or anything ? The starter solenoid is normally on a bracket on the block , as you are looking at the engine from the front of the car it is normally 4" below and 4" to the left of number 4's spark plug . You can't miss it as it has the big cable from the starter motor going to it and another from it under the car . Just follow the big cable from the starter and you'll find it if it isn't in the normal spot . If the wiring is that bad maybe you should look at getting a nw wiring harness and replace what's there already before it causes you heaps of grief .
PostPosted: Mon May 14, 2007 2:47 am
Are all modern mechanics like that or was this guy just joking on his profile?
PostPosted: Mon May 14, 2007 7:22 am
Hahahahahahahahahahahahahahahahahahahahahahahahahahahahahahahaha!!!!
Apparently they are? According to him! Mainly because new cars are so completely different to old ones.
Users browsing this forum: No registered users and 348 guests
