It is currently Tue Aug 05, 2025 4:13 pm
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun May 13, 2007 8:16 pm
Here is a pic of the flog who owns it..... http://www.cardomain.com/ride/2071662
PostPosted: Sun May 13, 2007 9:07 pm
He's a bad dude, I wouldn't want to mess with him.
Reminds me of Lee Hotti. 8)
PostPosted: Sun May 13, 2007 9:12 pm
Oh yeah, u bet!!!
U should check out his cardomain page.... http://www.cardomain.com/ride/2071662
He listed this as a future modification: * 81°C Cooler Thermostat
PostPosted: Mon May 14, 2007 12:24 am
henry the mini wrote:
Is this Commodore photo has been taken in Geelong? Tons of P-Plate here seem to buy mag two at the time. Have a look for the amount of car with only two mag, you will be amaze.
I went to cairns in febuary, rented a Bini with the intention to fang it to Karunda, iwas stuck behind a bus both way :x . A bit sad really
thats so taht when you do burnouts the expensive tires dont get ruined,
most people actually ahve the other 2 rims in shed or boot, as tires on 18s can be up to 350/260 dollars a piece
where as u can pick up stockies/pursuit rims for 100 bux 4 for
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon May 14, 2007 12:41 am
My dunlop formula R's were 120 each, gotta love normal profile tyres.... :P I mean I guess there isn't much rubber in a mini tyre though....
Alternative to putting 'stockies' on the back and yes I have some mates who have.... Just don't do skids, geez, not that hard. :roll:
PostPosted: Mon May 14, 2007 12:54 am
wheres the fun bro
my best m8 has a valiant with stockies and hubcaps 8)
60 bux a tire new tires tomorrow 8) 8) :D 8) 8)
i have 17s all round on my commodore my bro "borrowed my stockies"
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon May 14, 2007 1:52 am
As far as i know my front end panels are all standard. Since the 12s were put on, the front tyres also just knick the guards on full lock. Usually only if there is a bump in the road when doing a U-turn...
I just raised the height a touch and it's been fine since.
As for burnouts in commondores- BOOOOOORRRING
Carl
PostPosted: Mon May 14, 2007 7:27 am
I would have thought the front apron panels should be the same, some are for rubber mounted subframes tho. Mine i believe is for a solid mount. Thats wat was ordered from Mini Kingdom 10yrs ago!
Mine dosnt just nick, it really fouls bigtime! As in u cant turn the wheel any further! Plus my 12in tyres are only 55 profile to!
As for tossers running round with chasers on the rear.
The flog in the above pic actually told every one on the "Just Commodores" chat forum that he traded in 4 good 18in rims/tyres, and all he was able to get in return was 2 19in rims/tyres.... He had to save up to afford the other 2.......
PostPosted: Mon May 14, 2007 11:10 am
why bother, hes only gonna get defected, and by the looks of things theres not even any rubber in the guards :?
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Jun 11, 2007 9:55 pm
Hanra / Sox61:
I'm contemplating a front end panel swap from a Rover on my 68 Deluxe as it has multiple dents/broken bits/rust/bits cut off or belted flat during an engine swap a coupla decades ago by a previous owner :(
Can you give me any advice or words of caution? I'm still pretty new to Minis and just heard about the solid/soft mount difference a few days ago. Prior to that I was thinking the swap might be relatively easy, now I'm not so sure. Would I need to use a Rover front subframe?
I intend to keep the 10" rims on it, they house the Cooper S disc brakes nicely 8)
( And they say the search function doesn't work - ha! :P )
the internet wrote:
Like Audrey Hepburn, almost everybody loves the Mini. The only people who didn't love the Mini were pathetic, empty people.
PostPosted: Tue Jun 12, 2007 6:21 am
:lol: that commodore guy is a tool.....
anyway,
where do your tyres scrub? just below the panel join to the wing would be my guess?
PostPosted: Tue Jun 12, 2007 7:16 am
Yeah, just below the seam. But ive had it all chopped out now....
PostPosted: Tue Jun 12, 2007 7:27 am
i guess its hidden by your flares ?
My 10's used to rub there due to worn cones, being a rover shell i guess thats a moot point, but is the shape of the panel actually any different?
(the 10's are now on my elf and rub because the hydro is empty 8) (
