It is currently Sun Jul 27, 2025 11:11 pm
 Post subject: early metro ball joints
PostPosted: Thu May 17, 2007 7:45 am
Hi all
Karcraft just told me they will not be getting any early metro ball joints until atleast late june early july. Does anyone know of anywhere I may be able to get these sooner.
Thanks in advance
Michael
blokeinamoke wrote:
PostPosted: Thu May 17, 2007 8:45 am
MG Heritage at smithfield NSW.
Dan
PostPosted: Thu May 17, 2007 2:01 pm
Epay.co.uk
PostPosted: Thu May 17, 2007 4:31 pm
I got a quote from MG Heritage and it was $45 each... So...
Is this what i need?
It is so confusing - Austin, Rover, Metro, Turbo...
http://cgi.ebay.co.uk/AUSTIN-METRO-UPPE ... dZViewItem
 Post subject: ball joints
PostPosted: Thu May 17, 2007 9:21 pm
yes, you need before 84 ones
blokeinamoke wrote:
PostPosted: Thu May 17, 2007 9:37 pm
Not sure if what you need? The difference in the two ball joints is the diameter of the taper.
So if you are using mini suspension you should be able to use mini ball joints???? because the taper will fit into the upper arm and the lower arm.
Dan
PostPosted: Thu May 17, 2007 9:47 pm
no they are totally different,
metro ball joints have no shims and a more of a bolt type arrangement that screws into the uprights.
early metro ones have a smaller taper which suits the mini control arms. the later metro ones have a thicker ball joint shaft with a different taper.
blokeinamoke wrote:
 Post subject: Re: ball joints
PostPosted: Thu May 17, 2007 10:20 pm
so they're throw away whe they're worn?
PostPosted: Thu May 17, 2007 10:26 pm
Yes, like any other car... :wink:
Users browsing this forum: Barkfast, Bing [Bot] and 93 guests
