It is currently Wed Jul 30, 2025 3:44 am
 Post subject: Which door to use?
PostPosted: Thu May 17, 2007 6:28 pm
I have two doors. The one or orriginaly on the car is fairly rusty but quite "straight" and i know this one fit the car. The other one got only suface rust but got quite a few dint and bump on it, also got a bit of surface rust inside the skinn. I dont know if this door will fit well on the clubby.
Simple question, should i have the original one fixed (expensive) of used the spare one?
Also does anyone know a mini friendly panel beater in Geelong?
Thanks
Louis
PostPosted: Thu May 17, 2007 6:34 pm
High heel ninja
Dents are easier to fix than rust.
Doogie
PostPosted: Thu May 17, 2007 9:54 pm
they are both clubbie doors yeah? otherwise, fitting morris doors to clubbies and vice versa is a bit of a challenge..
PostPosted: Thu May 17, 2007 9:58 pm
Yep both clubby door, same year, just different probleme.
Please Help me, all of you!!! :oops:
PostPosted: Thu May 17, 2007 10:21 pm
I'd find a door that doesn't have rust OR dents... easy....
PostPosted: Fri May 18, 2007 12:04 am
post some pics mate, it might be easyer than u think
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
Users browsing this forum: Bing [Bot] and 87 guests
