It is currently Wed Aug 06, 2025 7:44 pm
 Post subject: Odd A+ Engine Number
PostPosted: Fri May 18, 2007 7:45 pm
Visited a new Ausmini member tonight....interesting, rivetted, aluminium engine tally plate on a small bore.
B or PHM1270ET1088A
.............AD...............
BMC remanufactured engine???
 Post subject: re engine number
PostPosted: Fri May 18, 2007 8:57 pm
will be a aplus 998 engine,factory remanufactured as they generally start with the bhm number,as i occasionally get the 1275 version in the aplus's,quite common in the uk
 Post subject: A+
PostPosted: Fri May 18, 2007 8:59 pm
Ohhhhh?? this engine had side plates....maybe I'm getting confused with A+1275....but, I thought all A+s were the later, no side plates, stronger block?? Hmmmmmmm :?
PostPosted: Fri May 18, 2007 9:06 pm
The only engines without side plates were the non-Cooper S 1275.
 Post subject: A+ 998
PostPosted: Fri May 18, 2007 9:27 pm
Thanks Mike, 1100S only.....no side plates.
So how young are A+ 998s :?:
 Post subject: Re: A+ 998
PostPosted: Fri May 18, 2007 9:28 pm
1980 on. :wink:
As well as 1100S, there's all the others of course that ran that same block with no side plates.
And the A+1275s as said.
PostPosted: Fri May 18, 2007 9:31 pm
Wow :shock: ...the man has a modern engine in the old deluxe and didnt know it. So were there refinements in A+ over A Series???
PostPosted: Fri May 18, 2007 9:32 pm
We bought an old Clubby once that had an A+ 998 in. Painted yuk yellow it was... the motor that is.:lol:
PostPosted: Fri May 18, 2007 9:34 pm
Not just 1100S.
1275 in Sprite, Midget, Austin America, Morris 1300, Allegro, Marina, Metro, Maestro, Montego, Mini, etc. had no side plates.
By comparison they only made a handfull of 1275's with side plates. :wink:
PostPosted: Fri May 18, 2007 9:36 pm
They were cheaper to make. 8)
PostPosted: Fri May 18, 2007 9:41 pm
Thanks Doc....was it VHT?? :lol:
PostPosted: Fri May 18, 2007 9:42 pm
Not just 1100S.
Mike.....are you saying MKI Cooper S non-thick flange was only a handfull :?:
PostPosted: Fri May 18, 2007 9:48 pm
By comparison, I'd say he's saying 'yes'.
It's the way to weed out Cooper S engine fakers. A lot of people say thier 1100S is an S motor which is a fair enough thing to say to non-mini people, as saying 1275 may not mean a lot.
But to other mini people, it's known there is a big difference between S motors and non-S.
What is the reason for the side plates? I had to take my breather sid eplate off and put an 850 one on (which is different, it looks different) and ran a rubber pipe with a tube as my breather.
PostPosted: Fri May 18, 2007 9:53 pm
The side plates are there to make it easy to remove or replace the cam followers.
But on the 1275, they made the block stiffer by doing away with them. :wink:
Downside is it's near impossible to swap cam with the motor in the car.
Last edited by drmini in aust on Fri May 18, 2007 9:54 pm, edited 1 time in total.
 Post subject: Clutch
PostPosted: Fri May 18, 2007 9:54 pm
They were inspection plates and probably used in some service operations....but they do weaken the block.
Same car has an interesting fault....when cold, no first and second, after warm up....1, 2, 3, 4.....the clutch master cylinder fluid level was about 30mm below the lip:shock: .....I suggested he lift his carpet and see if the Master has sprung a leak :roll:
Users browsing this forum: No registered users and 46 guests
