It is currently Tue Jul 29, 2025 8:31 pm
PostPosted: Wed May 23, 2007 7:56 pm
i only jsut put the radiator back in last week
it was the hardest its ever been, prolly cos fresh paint!!!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed May 23, 2007 8:31 pm
Yeah... changing speedocable sukz.... I noticed, 2 years ago, that i`ll need another cable.
Just, as the engine was back in and ready to run for 2-3 hours... *ARR!* :twisted:
Anyways... Hope you don`t need to change it for the next years :D
PostPosted: Wed May 23, 2007 8:40 pm
she wont get driven much but it would still be nice to know how its goin!!
shes we low
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed May 23, 2007 9:35 pm
why do you have to change it?
the last one i changed just the inner cable was broken, the small plastic tip, i just pulled it out and put in a new cable. no need to remove the outer hull
Rover 214 atm ....
PostPosted: Wed May 23, 2007 10:05 pm
i didnt think it had one
or the end was a different size/ style
but it was all good
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
Good luck getting a jack under that, maybe one of those alloy extra low trolly jacks will be the trick.
Roundies Rule !!!
PostPosted: Wed May 23, 2007 10:13 pm
full lock is my friend :wink:
turn the wheel full lock, n slip a trolley jack between the back of the front wheel and the guard!!
jack needed a few hits with the sledgie, but it fits good now!!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Wed May 23, 2007 10:17 pm
Could also back up onto a wedged large piece of wood :wink:
PostPosted: Thu May 24, 2007 12:08 am
that is actually an idea i had for when the car is basically finished, some long ramps, just long enough to get a decent trolly jack under it,
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
Users browsing this forum: No registered users and 128 guests
