It is currently Sun Aug 10, 2025 2:12 am
 Post subject: forward jacking point
PostPosted: Thu May 24, 2007 7:52 am
I would like to confirm the location of the forward jacking point on the forward subframe.
The photo below shows an upside down L shaped bracket which secures the nudge bar to the subframe. I am assuming that a suitable jacking point for lifting the front end of the car is immediately aft of the bracket, on the (mostly) flat flange that the bracket is bolted to ... yes ?
-- Simon // VMCI Member 2674 --
PostPosted: Thu May 24, 2007 8:09 am
look at my post here
http://www.ausmini.com/forums/viewtopic.php?t=22248&highlight=block
michael
PostPosted: Thu May 24, 2007 8:46 am
See how your subframe is all bent around where the nudge bar attaches.... that's because that spot ISN'T a jacking point, but people have been using it for one.
I always use the original jack, in the factory lifting point.
PostPosted: Thu May 24, 2007 8:50 am
High heel ninja
Jack it up either by putting the jack on the sump, or at the castor arm mounts at the front of the subframe.
Doogie
 Post subject: Jack
PostPosted: Thu May 24, 2007 8:54 am
Which is marginal safety-wise at best :D Get the body onto blocks or axle stands as soon as you can before doing anything but a quick wheel change etc The first time you see one of those old worn-out side-entry screw-jacks slowly "unscrew" it is a real eye opener!! :shock:
The block of wood jacking aid works on the front and rear subframes just fine.
PostPosted: Thu May 24, 2007 1:44 pm
You should NEVER jack the car by using the sump.
In my experience using the factory points isn't very good, using a trolley jack lifts the rear wheel slightly as well. I use the X member immediately behind the front panel under the bumper. Depending on the type of trolley jack used, a piece of timber might be required to space the lifting arm away from the front panel.
 Post subject: jacking
PostPosted: Thu May 24, 2007 2:40 pm
I will throw in my 2c worth,
A mini gearbox/sump is quite strong, jacking on it is NOT a problem providing your jack has a fairly large surface area. (don't use a little bottle jack etc.) I use a large/low trolley jack.
When jacking using the sump ensure that you watch the engine as it goes up, if one side of the engine raises before the other you have a bad engine mount and I would suggest replacing it ASAP.
I have jacked 1000's of minis on the sump and NEVER had a problem, Like any car however never leave it on the jack to long and ALWAYS use jack stands when working on them.
Regards,
Andrew
Andrew@Minisport, South Australia
Ph: 08-8177-1275
Skype: minisport.au
www.minisport.com.au
Minisport for all your mini parts
PostPosted: Thu May 24, 2007 2:50 pm
The only that scares me about jacking a mini up by its sump is the upwards pressure of the jack, against the downwards force around the engine from the car. Thats a lot of stress to be putting on your engine mounts in the wrong direction ?
No more Minis!......For now.
PostPosted: Thu May 24, 2007 2:55 pm
Most mounts can handle it no probs,
If your mounts broke they probably where not far away from braking anyhow.
I will put it to you the sump is stronger than the subframe. (I have seen hundreds of the subframes all bent due to people jacking on them)
Andrew
Ph: 08-8177-1275
Skype: minisport.au
PostPosted: Thu May 24, 2007 2:56 pm
with a trolley jack, i do it from the front suspension arm to subframe mount...
other than that i use the factory hole.... with the original jack
 Post subject: Ouch!
PostPosted: Thu May 24, 2007 3:38 pm
Andrew
Have you seen the rubbish that passes for rubber in some aftermarket mounts??? It might be expediant for you, but I certainly wouldn't be recommending it to others :!: :D
PostPosted: Thu May 24, 2007 3:54 pm
I've been jacking my minis and mokes from that point for 20 year without any problem. Yours does look a bit manky though.
PostPosted: Thu May 24, 2007 4:07 pm
Thanks for the excellent, and diverse, responses.
Would it be fair to say that load distribution is important when jacking up a mini?
The mini workshop manual recommends using the subframe points only when lifting is occuring at all four points simultaneously, for example when the car is lifted on a garage hoist, as per http://s70.photobucket.com/albums/i91/Hanras/A%20General/?action=view&current=27.jpg. I assume this means that lifting the car at only one subframe location results in ~4 times the load at a single point, potentially damaging the subframe, as shown in my initial photo.
Additionally, the mini workshop manual recommends that X member on the front of forward subframe, in conjunction with a load distributing wooden block, offers sufficient load distribution to raise the front of the car without crushing structure, as per http://s70.photobucket.com/albums/i91/Hanras/A%20General/?action=view&current=26.jpg. Minibob and Minimick also recommend this approach.
Does that sound reasonable?
PostPosted: Thu May 24, 2007 4:12 pm
That sounds pretty well right I reckon, but I have jacked the car on the single points you are reffering to always bearing in mind that I want to get the axle stand in place as quickly as poss. Using the front member also means that I can get both axle stands under the subframe/susp mounts together without phaffing around on both sides.
PostPosted: Thu May 24, 2007 6:33 pm
I'v always used the juntion between the Tie Bar, Subframe and the body for the front with a trolly Jack. Gives me plenty of room for the Axle Stands. I would not even think of using the Sump just incase of the Engine Mounts :shock: .
Rear is the Subby :wink:
Users browsing this forum: No registered users and 125 guests
