It is currently Thu Jul 24, 2025 12:26 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Thu May 24, 2007 11:50 pm
kasperflipped wrote:
On a similar note, how do you tell whether you need a "resistor" coil or a non one? is there something in my dizzy that will tell me as my current coil has no labels on it
i have 2 gt40s
one has USE WITH RESISTOR on the sticker...
PostPosted: Fri May 25, 2007 9:30 am
i have 2 gt40s
Look underneath-
if it says `12V' connect it straight in. It's 3 ohm.
If it says `use with resistor', do so. It's 1.5 ohm. Ballast resistors to use with it can be got from supercrap etc.
Not that if using a Pulsar dizzy, they take the `use with resistor' type coil, but use no resistor. Yes they will work with a 12V one but give less spark voltage.
