It is currently Wed Jul 30, 2025 12:46 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat May 26, 2007 2:23 pm
Hanra wrote:
Why dont people just pull the ROTOR BUTTON out of there dizzy when they leave the car parked?
The only way to steal it is to push it, tow it, or happen to have a Mini Rotor Button in there pocket at the time of theft.....
me and a mate did this in his valiant in elizaabeth!!
except he coodent get it back in man it would have looked sus!!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sat May 26, 2007 2:24 pm
I did it once and the little carbon brush in the cap fell out onto the road not to be found.... :x
PostPosted: Sat May 26, 2007 7:05 pm
slinkey inc wrote:
Immobiliser is great, stops fuel, starter and ignition. To go around these things the car would need rewiring, which could be done, but ain't no gone in 60 seconds.
This just shows how little you know. I used to work in a wrecking yard and we used to get a lot of cars with immobilisers. I used to bypass the immobiliser in about 15 seconds. 8)
If the car has a carby I would not bother with an immobiliser, the crook is going to bypass it when he hotwires it anyway.
There are a few things you can do that will work.
1) A battery switch on the battery cable under the floor.
2) A fuel cut off switch under the car.
3) A fuel cut off switch in the boot.
4) A lock on the handbrake. (A hydraulic lock on the brakes will also work but is not legal for road use)
5) A lock on the gearchange.
PostPosted: Sun May 27, 2007 10:37 am
I is a mookenik
hmmm this is true if u have an electric fuel pump installed ur at an advantage a mate of mine use to undo is spark plugs when he bought mini, and has anyone got the steering lock in the steering coloums
PostPosted: Sun May 27, 2007 10:42 am
I left my car at a dyno place. And the owner of the place stuffed something and couldn't get the car started, and due to my dash setup, a wire was out the window down the front and under the bonnet.
Morris 1100 PM, what is the issue about carbies and immobilsers not working?
The other thing is, if you could by-pass one in 15 seconds (took the dyno guy an hour... :roll: ) could the average 16 year old joy rider?
PostPosted: Sun May 27, 2007 11:42 am
The problem with immobilizers on a carbie car is that the only thing they can restrict is fuel and current. Both of which can be routed around to get around the immobilzer.
My solution would be padlock the car in reverse by mounted a bracket on the floor and using a combination lock - a la Saab style
PostPosted: Sun May 27, 2007 11:44 am
I is a mookenik
lol this is true but what happens when u go out? i guess there is really no real way to protect ur mini from someone stealing it, juz have to pray for luck and hope to god no one trys to take it
PostPosted: Sun May 27, 2007 11:47 am
huh - your car would be in reverse - not a biggy Saabs have been doing it for decades.
PostPosted: Sun May 27, 2007 11:51 am
I is a mookenik
ah lol true this and how do u lock it in reverse
PostPosted: Sun May 27, 2007 11:52 am
:roll: :roll: :roll: :roll: :roll:
PostPosted: Sun May 27, 2007 11:54 am
I is a mookenik
ok dude that whole sentence confuses me LOL gonna need a diagram
PostPosted: Sun May 27, 2007 11:56 am
Bolt a bracket to the floor behind the gear lever. Pass a padlock around around the gear lever with the car in reverse and mount through the bracket.
Therefore you cant take the car out of reverse without removing the padlock
PostPosted: Sun May 27, 2007 11:59 am
I is a mookenik
hmmmm i like i like but i pain in the ass to do
PostPosted: Sun May 27, 2007 12:02 pm
Give Ash some flowers Nick .
That PITA would've been worth it if your car got stolen by some low-life.
PostPosted: Sun May 27, 2007 12:03 pm
I is a mookenik
so true in so many ways lol i usually park tiny behind other cars when i go out somewhere, i always seem to manage to park him in awkwards spots
Users browsing this forum: Bing [Bot], drmini in aust and 94 guests
