It is currently Sat Jul 26, 2025 6:17 pm
PostPosted: Sun May 27, 2007 5:02 pm
I was going through the shed today looking for stuff to get rid of.
I found a 29D Clubman GT dizzy. Took the cap off and it has a Luminition Magnetronic module in it.
I know nothing about this type of electronic ignition.
Anyone know about this brand of electronic ignition?
I googled this: http://www.ahspares.co.uk/products/LUMI ... LI199.aspx
Looks like it doesn't need a module unit out of the dizzy. Is that right?
PostPosted: Sun May 27, 2007 5:11 pm
Anton, I've not used one but I believe they are self-contained, like the Pertronix Ignitor is.
PostPosted: Sun May 27, 2007 6:49 pm
Interesting.....
Are they any good? I am thinking about giving it a whirl in my GT.
PostPosted: Sun May 27, 2007 8:44 pm
Yep they are good - set and forget like the others.
Just makes sure you retime after you install as the the timing can change slightly.
PostPosted: Sun May 27, 2007 8:49 pm
I forgot about watching out for tacho bounce which is known especially with these units
PostPosted: Sun May 27, 2007 9:34 pm
Hi Anton,
that is the version i was running before i fitted the megajolt unit, worked great for me mate, no issues in about 5 years of running
Grant
100% Pure A Series Turbo
PostPosted: Sun May 27, 2007 9:52 pm
Cheers guys.
So this replaces the points and condensor?
What coil do I use?
The one that was with this dizzy is a BOSCH, and on the bottom it says GMH - Use With Resistor
PostPosted: Mon May 28, 2007 7:46 am
I was using a std bosch coil with no resistor.
Grant
