It is currently Sun Jul 27, 2025 4:55 pm
PostPosted: Wed May 30, 2007 11:58 pm
Hey Guys,
Ive run into a little bit of a problem with clearance issues between my late model Twin servo master cylinder and the Dizzy Cap, (B16A2)
at the moment there is just not enough room where i need it with the current steel lines.. iv looked into braided lines and will change over to them as part the next thing i do (The rest of the brake system is braided) but the banjos that are on the market are huge and just aint gunna fit ( iv even tried Modified Banjo's)
iv looked into fabricating a plate on a angle to bolt between the servo & master cylinder to provide extra clearance but this comes with its own issues such as the pin would strike on a angle
What i would ideally like is a Master cylinder exactly the same specs but with the outlets on the opposite side ......If anyone has heard of such a thing could you please let me know, or if you have any other ideas or comments id love to hear from you
Thx
Ash
PostPosted: Thu May 31, 2007 10:08 am
If you search back through 13 sec's build you should find a photo of his master being turned about 70 degrees. He had the lugs cut of the master and welded in a different location.
Dan
