It is currently Sat Jul 19, 2025 12:41 am
 Post subject: Carb from a Torana?
PostPosted: Thu May 31, 2007 4:00 pm
A guy at work has a 1.75 in SU he doesn't need.
He knows nothing about it and I don't know much from looking at it either.
Does anyone know what type they ran and if it could be of use to me on a mini?
Thanks.
:D
PostPosted: Thu May 31, 2007 4:17 pm
British technology on a and Aussie (european) muscle car...
Hmmm. Dunno bout that one.
Im only assuming S.U.'s were a british idea?
PostPosted: Thu May 31, 2007 4:21 pm
yeah they had triple su's
PostPosted: Thu May 31, 2007 4:28 pm
True ay!! But was that stock on the GTR XU1? or GTR?
I would of thought triple strombergs not S.U.'s????
PostPosted: Thu May 31, 2007 4:30 pm
That right. Triple SU's. 8)
If you change the needle over you should be okay. If you got a pic, we might be able to tell you HIF44 or whatever
Inlet manifolds might be different also, so just get a new one.
EDIT: They were on torana's also I think
Spritey!
Lower your standards. Increase your success rate.
PostPosted: Thu May 31, 2007 4:36 pm
LC GTR: Two Bendix-Stromberg WW2.
LC GTR XU1: 3 x 150 CDS (1.5 inch) (38.1 mm) Zenith sidedraughts.
LC GTR XU1 Race Spec: 3 x 150 CDS Zenith sidedraughts, revised needles.
LJ GTR: Single downdraught.
LJ GTR XU1: 3 x 175 CD-2S (1.75 inch) (44.45 mm) Stromberg sidedraught.
LJ GTR XU1 Race Spec: 3 x 175 CD-2S (1.75 inch) (44.45 mm) Stromberg sidedraught.
PostPosted: Thu May 31, 2007 5:03 pm
I think the Viva based Towana had an SU?
PostPosted: Thu May 31, 2007 5:05 pm
Thats cause the Torana is a European car as with all Holdens cars.
The HB Torana was taken from the Vauxhall Viva.
PostPosted: Thu May 31, 2007 6:34 pm
Triple SU's were a popular mod to 202 Torana's back then, or so I'm told. Well SU's look better anyways, haha.
 Post subject: carb
PostPosted: Thu May 31, 2007 6:59 pm
Triple SU's are a popular set-up for Holden Powered sixes, I've run 1 3/4SU's on a 202 in the past.
The Carbs are exactly the same carbs, just different needles will be needed.
The factory triple carb set-up was indeed CD Strombergs but the aftermarket stuff is also SU's and Webers.
They also ran Triple Split Choke Webers on the Bathurst race cars too.
PostPosted: Thu May 31, 2007 7:03 pm
Depending on the Carby/manifold that was used, it would be worth your while to check the float chamber angle. Won't necessarily be the same as a Mini. If not you can buy the little plate that sets this level.
PostPosted: Thu May 31, 2007 7:09 pm
No Holden came from the factory with an SU.
Holden had a tie in with Stromberg so that was all they could run.
Lots of Holdens were hotted up with twin or tripple SUs.
PostPosted: Fri Jun 01, 2007 7:33 am
Thanks for the responses sofar guys. :D
Here's a couple of dodgy snapshots of it:
 Post subject: carb
PostPosted: Fri Jun 01, 2007 8:00 am
Thats definately a CD stromberg carb.
Your best bet would be to buy it, sell it on ebay and then buy a real SU carb. You'll probably have enough cash left over for a sixpack too
PostPosted: Fri Jun 01, 2007 8:06 am
Yep thats a stromberg - the second photo shows it clearly.
