It is currently Thu Jul 24, 2025 6:30 am
PostPosted: Fri Jun 01, 2007 5:24 pm
I'm currently stripping my mini body for a repair and respray. I wanted to remove the sound deadener on the underbody to carry out rust repairs and replace it, and a guy I know said to use the oxy to heat up (not burn) the deadener and just scrape off with flat tool or the like.
I commenced yesterday, and the stuff just peels off like magic. It's a bit messy keeping the tool clean but had the stuff off in no time. Just had to ensure all flammable bits on the inside were off as well.
Brian
PostPosted: Fri Jun 01, 2007 9:09 pm
Oxy is a bit drastic, a decent electric heat gun works pretty well. My Makita gets so hot i can silver-solder with it... :shock:
PostPosted: Fri Jun 01, 2007 10:14 pm
I fixed rust on the bottom of my 1000s, all i did was clean it off with a wire wheel on a grinder the weld new metal on. Any left over under sealer just burns out of the way.
PostPosted: Sat Jun 02, 2007 12:47 am
Heat Gun the Wire Wheel it
PostPosted: Sat Jun 02, 2007 12:52 am
is that underneath a van?
PostPosted: Sat Jun 02, 2007 3:28 am
yeap
PostPosted: Sat Jun 02, 2007 7:21 am
section nearest to the roller door is where the tank goes
PostPosted: Sat Jun 02, 2007 9:12 am
here's a before pic also
PostPosted: Sat Jun 02, 2007 4:20 pm
It was a cool flame from the oxy, but after seeing the photos - sounds like a heat gun and wire brush is the go. Could eat your dinner off it!
