It is currently Mon Jul 21, 2025 8:17 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jun 04, 2007 12:41 pm
perhaps....
who knows where i'll strike next
PostPosted: Mon Jun 04, 2007 1:03 pm
Mines 2.5inches straight through with only a CAT, no muffler. From the turbo to the firewall is steel pipe and from there to the tip is Stainless, it spunds great.
Dan
PostPosted: Mon Jun 04, 2007 1:18 pm
Hanra wrote:
Have u heard my car?
No flexi joint. Its one solid piece from the extractors to the tip, its all welded together, n held up by 2 seperate rubber mounts at front/rear of rear subframe, and solid bracket to the diff housing.
yeah a flexi seems to be the only thing you are missing...
but if you dont drive it much then i wouldnt bother?
Where does this flexi section fit on the system? Whats it look like?
PostPosted: Mon Jun 04, 2007 1:28 pm
fits between the manifold and the pipe
PostPosted: Mon Jun 04, 2007 5:34 pm
I've not had a car with a flexi joint, but I've heard they have a tendency to burn out (larger surface area exposed to the heat, sort of makes sense), and several well-respected Mini specialists don't like them much. I suggested putting one on my exhaust to a specialist, and he told me he wouldn't do it. We later found out it's the least of my exhaustive concerns... :roll: I believe later model Minis may have had flexi joints standard..? But I don't imagine they help performance.
The main purpose is to allow for a little more flex between the engine and the body - useful if you've got dodgy engine steadies, although fixing the engine steadies is a better (and cheaper) idea. I don't imagine you have dodgy engine steadies, though. If your engine is nicely mounted, a flexi joint shouldn't be mandatory. :wink:
Mini Mad, sounds nice, but it's nowhere near loud. Just very nice! :) You might need to share your current exhausnt note Hanra, so we know how loud it needs to be. I'd reckon my car's loud enough to suit you, but it's not a system anyone would recommend. :lol: :roll: :oops: I didn't choose it...
PostPosted: Mon Jun 04, 2007 5:39 pm
Why does he need a flexi joint for Spaceboy.... :roll:
His system is welded at all joints so no flanges etc
PostPosted: Mon Jun 04, 2007 5:45 pm
I've been using 2 inch, straight through exhaust with LCBs since I got the car going.
It seems good enough, plently loud enough. No flexi-joint, no need what so ever. I'd say you might need one with rod change but with remote, nope.
Since I supercharged my car it sounds quite different. It has a bit more of a buzzy or zingy exhaust note under boost.
I'd stick with the 2 inch system with LCBs and just be happy with that, I don't see much advantage from going down in size. A dyno might be the way, if you care that much, I wouldn't.
PostPosted: Mon Jun 04, 2007 5:53 pm
I think ill pass on the flexi joint. I only had an issue bottoming the pipe out on a trailer that i had never used b4.
Ive got an engine steady on either side of the motor with new bushes along with new engine mounts. So there is not a drama there.
I just thought 2in maybe to big, i chose this system when i was a 17yo kid. And was still under the belief that bigger is better. Im more thinking of changing the muffler setup tho.
Because its such an open system, it does tend to almost sound like its sucking air on the gear changes... Hard to explain, but it kinda has a funny note to it when off the gas.
PostPosted: Mon Jun 04, 2007 10:24 pm
Good choice - if you haven't had flex problems before, no point in worrying about them. :wink:
A 17 year old kid (well, he was around that age when he set it up) chose my exhaust, that's why I've got a 2.25" system, with 2" full race 3-1 headers... :roll: I'll change them soon enough. I'll have to listen and see if it makes a sound similar to what you've described next time I take it out... :? It's LOUD though! :lol:
PostPosted: Mon Jun 04, 2007 10:27 pm
I is a mookenik
i run a 2" all the way with i think its 3" muffler that takes up half the car then goes into a 3" apex sports cannon apparently according to everyone thats cruised with me its got a nice tone to it
PostPosted: Tue Jun 05, 2007 8:08 am
I still think the best sound is from standad or racing 3-1's into a 1 3/4 pipe with RC40 attached and it give out a great sound and has the torque and HP readings to match.
PostPosted: Tue Jun 05, 2007 12:25 pm
Give Ash some flowers Nick .
I run a 1¾" S/ST LCB into a 2" MS pipe with a sports exhaust (2" tip). I think it's loud because everyone I talk to says that they hear my car before they can see it but I can't even hear the exhaust over the induction hiss from my carbies.
I will be going louder next time - probably a straight through exhaust.
PostPosted: Tue Jun 05, 2007 12:43 pm
*sigh*
Users browsing this forum: No registered users and 61 guests
