It is currently Fri Jul 18, 2025 12:49 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Tue Dec 14, 2004 6:47 am
dewey wrote:
I just put an 82* thermostat in it and it was running perfectly on the mid-point on the smiths guage. It took about 5 minutes to get to that temperature. This was with the lucas dizzy.
Since I've put the pulsar dizzy in the car, I've found that it takes a lot lot longer to get to temp and generally runs a bit below the mid-point when I've managed to catch a few lights in a row. Sits on the mid-point when its been idling for ages though. I wonder why this is?
dewey
Probably has more proper low & midrange advance- your Lucas may have been retarded some at low speeds. Old ones get pretty loose inside.. :cry:
And if you had checked the ign timing for #1 and then #4, I bet they would have been different too!
PostPosted: Tue Dec 14, 2004 7:33 am
damn those retarded lucas dizzy's!
dwightgunning.com
