It is currently Wed Jul 23, 2025 2:11 am
PostPosted: Mon Jun 11, 2007 7:23 pm
Hi,
I just bought a mini-matic with the hydro suspension (obviously) and i'm guessing it has a leak coz the wheels are right up in the guards and she sits about 3cms off the road. So I was wondering if anyone could point me in the right direction of who to get to fix/pump them back up? I'm in south east melbourne, any advice or names and numbers thrown my way would be greatly appreciated.
Thanks
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
PostPosted: Mon Jun 11, 2007 7:29 pm
Try clubmn he is in Melbourne and does them although it may have a leak in the system somewhere to be that low.
Cheers Pete
http://www.ausmini.com/forums/profile.p ... ofile&u=96
PostPosted: Mon Jun 11, 2007 7:33 pm
If there's a real leak it'll only be down on one side.
It probably just needs a pump up. They need this every year or 2. :wink:
 Post subject: Valves??
PostPosted: Mon Jun 11, 2007 8:30 pm
As the Doc said...probably not a leak....go around to the back of the car, look under the bumper bar and find the two schrader valves (just like on the tyres)....are there valves in the both lines???
If yes...then someone may have just let the pressure out or the valves have failed and allowed the system to let down.
2c
PostPosted: Mon Jun 11, 2007 8:32 pm
My car sat for five years and was down - i pumped it up with the BMC robot with the levers and it happily took fluid. Its not under that much preasure so leaks should be uncommon (at least on a car that has not been abused with the wrong fluid combinations).
 Post subject: mm1275
PostPosted: Sat Jun 16, 2007 6:08 pm
Thanks mate, now i know where all the Victorian mini's has gone!!!
