rehab1964 wrote:
You would need a pair of diff output shafts , side covers and drive flanges off a Cooper S or Morris 1100S. (for steel unis).
Minimatic bits fit too, except the side covers.
If you just want to run the 1100 rubber joints, pinch these bits from your 1100 box.
<edit> as it's a rodchange box you need to keep the RH side cover, bore it to fit an S bush and seal if fitting steel unis.
I'm happy to run with the rubber uni's (I thought the steel ones with the nylon caps were very hard to find now)
how do I tell if it's a rod change 'box? I have the shiter mechanism here on the floor - it has two rods with two different fitting going forward to the gearbox.
If I stay with rubber uni's do I need to fit the S bush?
Yes you have a rodchange box there.
If using rubber unis the bush in the side cover is same as your 1100, so leave them, but you need the 2 diff output shafts and drive yokes off your 1100 box or another.
The reason to keep the RH side cover on a rodchange box is it has an ear that retains the main selector detent spring.
I'd replace both the side cover seals, and the bushes too if worn.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
