It is currently Thu Aug 07, 2025 2:12 pm
PostPosted: Tue Jun 12, 2007 9:27 am
Main cause of this vibration is not warped discs, but discs with uneven thickness. They are cast iron, develop hard and soft spots with use.
.001" thickness variation is too much, you will feel it in the pedal.
Get them machined on a drum/disc lathe by a reputable brake repair place. :wink:
Min thickness limit for machining on S discs is 8.0 or 8.5mm........
PostPosted: Tue Jun 12, 2007 10:17 am
i had a look through my manual, but i can't find the machining tolerance for the discs, anyon know?
BTW, a repco machine shop charged me 11 dollars per disc if I pushed them accross the counter as opposed to them pulling them off. Then the price went up to 50 dollars per disc.
PostPosted: Tue Jun 12, 2007 12:25 pm
If looking for thickness tolerance, it's not in there... :lol:
I always measure new ones, if more than .0002" (2/10s of a thou)variation I take em back... :wink:
PostPosted: Tue Jun 12, 2007 1:25 pm
Hello, just a thought on the vibration bit:
1) check that the disc is bolted on correctly and true. You can easily have a warped flange or bolt the flange on not quite true, giving you a rotor that is not 90 degrees to the axle. It also throws off your hub nut torque.
Check: get a dial gauge and magenetic block, set it up so that dial gauge is right angles to the rotor surface, spin the rotor and there should be 0 movement side to side.
Remedy: Pull it all apart, check the disc for warping, check the flanges for warping or burrs, machine both if necessary. When bolting on the and flange, use the wheel nuts and some hardenned washers to pull the flange down flat at full torque, before doing up the hub nut. Check again with dial guage.
2) What type of pads are you running? some bad/el cheapo pads and do all sorts of wierd and wonderful things.
Check: For pad glazing and uneven wear
Remedy: EBC Black Stuff pads or similar carbon kevlar pads.
Hope that helps
Lillee - 1969 Morris Mini K
