Tadhg wrote:
What I was told by the fitters at TAFE (a few years ago) was that, in a perfect world, there isn't much between a micrometer and vernier calipers.
I am a toolmaker and can tell you fitters don't know the difference between a vernier and a G-clamp
(ducks for cover) Nb, Fitters and toolmakers are roughly the same trade, but fight like civil and mechanical engineers do.
Anyway, True, in a perfect would there isn't much difference. the world aint perfect though and a vernier is only accurate to about 0.05mm (2thou approx) even when the numbers are reading to 0.01. Some would argue feel gets you by but truely even micrometers aren't perfect when they are new, verniers are affected by heat and pressure much more so.
Even still, I use a digital vernier all the time for comparative measurements, like diameters of silver steel or 0.1mm fractioned drills etc. Its easy to read and does the job. Mitutoyo and I've had it for about 12-14years
I use my micrometer/s for anything I need to measure accurately be it shims or journal sizes. They are also Mitutoyo and about 10years old.
If you buy one second hand, look at the faces and check the scratches, some are hardly used, hence the sale. If you think it's bent, look up at the light, same as you would check your vernier from time to time.
Daniel
