It is currently Sun Jul 13, 2025 11:07 am
 Post subject: Rebuilding a mini
PostPosted: Fri Jun 15, 2007 9:09 am
I am currently in the process of starting a new project.
I have a bare shell and all the bits.
My question is
What is the correct order of reassembly?
I know a big question and a bit ambiguous.
What are your thoughts? :D
68 Mini
70 Moke
PostPosted: Fri Jun 15, 2007 9:11 am
I'm sure you'll get countless versions of how to do it but I'd say
Bodywork and paint
Wiring
Subframe , suspension and brakes
Engine etc in from the top (personal preference)
Interior trim
Glass
PostPosted: Fri Jun 15, 2007 9:57 am
as i am finding, there are alot of thins you have to do before other things.
eg wiring before fuel tanks in etc, things like that
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Fri Jun 15, 2007 11:21 am
Bodywork and paint
Wiring
Interior trim
Glass
Sounds like a sensible start - I'd suggest you try and mimic the production line process as much as possilbe. You might have to work around the fact that the subframe, running gear and engine were probably assembled seperatly and joined to the body later in the 'line'. But as a rule always leave the trim and windows last. :D
 Post subject: order
PostPosted: Fri Jun 15, 2007 3:12 pm
bodywork paint
subframes(brakes, suspension)
side glass exterior trim
engine gearbox
wiring
interior
front rear glass
blokeinamoke wrote:
