It is currently Mon Jul 21, 2025 12:46 pm
 Post subject: Water spray
PostPosted: Sat Jun 16, 2007 9:58 am
On previous cars I have always sprayed water into the inlet manifold with the car under load to decarbonise the engine. This is followed by an Italian tune-up. Always worked well.
Anybody else do this to their mini/moke?
PostPosted: Sat Jun 16, 2007 9:59 am
DOne the water toture several times , only a fine mist from a squirt bottle and only sparingly , never had problems with it .
PostPosted: Sat Jun 16, 2007 10:18 am
can you describe that in a bit more detail, stephen? it sounds interesting..
 Post subject: 4 ta 1
PostPosted: Sat Jun 16, 2007 12:10 pm
Four to one water and kero (1 part) also works good ....but you really should be taking your head off if you are that concerned about carbon build up. There are places where carbon helps to form a seal etc.
 Post subject: Re: 4 ta 1
PostPosted: Sat Jun 16, 2007 1:12 pm
not worried about it being there already. More of a preventative thing.
- Cush - spray atomised water/alcohol/kero mix into the carb or inlet of a loaded engine will clean all the loose carbon off pistons/valves etc. Following by a quick red line run will blow all the now free crap out the pipe.
PostPosted: Sat Jun 16, 2007 1:25 pm
i like the sound of that!
what are the advantages/ disadvantages??
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sat Jun 16, 2007 1:32 pm
Disadvantages
too much water and car goes into hydraulic lock* but you need a lot
you remove too much carbon and it runs worse
the thermal shock cracks your piston
Blocks catalytic converters
Advanages
Its fun
It cleans the crud out of an engine
Its fun
Make sure you take the air filter off when you spritz the engine
It doesnt replace good maintenance of the engine and should only be done to healthyish engine
