It is currently Fri Aug 08, 2025 2:07 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2, 3  Next
PostPosted: Fri Jun 22, 2007 11:50 am
Location: Woodside, Hahndorf and Mount Barker South Australia
what ya got and whats wrong with it mechanical wise lol
people say keep ya friends close and you enemies closer BAH I say keep your friends close and your enemies at maximum effective range.
PostPosted: Fri Jun 22, 2007 11:57 am
73 mini.......sump plug thread, brakes-wheel cylinders,linings,drums, handbrake pivots and adjusters, fanbelt, speedo cable, radiator cap, coolant flush, hose clamps, throttle cable, choke cable, headlamp switch, temp sender, fuel tank sender, drive shaft coupling(rubber type),loose hubs, cv boots. well thats the important stuff anyway....(gulp) there is a not so important list haha
PostPosted: Fri Jun 22, 2007 12:17 pm
67 "Matic"...
- no paint
- no engine
- extremely bad wheel alignment
- loose wheel nuts
- rust patches
- dented front guard
- hydro suspension
- lots of other things wrong with it!
Soon to be totally transformed.
:lol:
PostPosted: Fri Jun 22, 2007 12:35 pm
78 clubby. ratty paint, smashed front, different colour bootlid. "sandblasted" widscreen, leaky window seals. speedo cable broken/not attatched. piston rings or valve stem seals on one cyl stuffd = running on 3 lowing lots of smoke, using lots of oil. soundls like a lawnmower. one mis-matched wheel (not the spare) drivers side quarter window not lockable, barrel missing from passenger side lock. drivers side door missing window seal. window winders hard to use. constant electrical problems, consistently bad brakes.
and i love it :D
78 Leyland Mini - Prince
PostPosted: Fri Jun 22, 2007 3:42 pm
Is this a thread for masochists :?: :lol: :lol: :lol:
PostPosted: Fri Jun 22, 2007 4:00 pm
1978 Clubby nicknamed `Bently'...
Bent front (it didn't keep left at chicane sign, haha) and subframe.
Stroked 998- PO overrevved it so it threw #3 rod cap out the front- trashed the gearbox case and block. :P
no rust though- surprising for a `78. 8)
One day it'll be resurrected. :wink:
<edit> Was sold last week to Kyoda. She can do it, I have enough projects already.:wink:
Last edited by drmini in aust on Fri Jan 09, 2009 6:19 pm, edited 2 times in total.
PostPosted: Fri Jun 22, 2007 4:16 pm
1971 Moke - one brake pipe and an air filter :P
PostPosted: Fri Jun 22, 2007 5:06 pm
what, is that all you've got for it?
PostPosted: Fri Jun 22, 2007 5:08 pm
wish my list was that short haha
PostPosted: Fri Jun 22, 2007 5:44 pm
I could add the Jag if that helps
1986 XJS - Claude
12 sparks plug to change,
one distributor to rebuild,
one a/c amplifier to fit,
four inboard rear brake pads to change,
one cruise control regulator to rebuild,
two FI plenums to reweld so that they are sealed,
one windscreen leak to fix,
one ecu to reprogramme once I have done the plenums,
one front valance to remove, derust, paint and replace.
and the Moke
1971 Moke - one brake pipe and an air filter (then its finished)
PostPosted: Fri Jun 22, 2007 7:05 pm
Must be an import :lol:
DOZ
PostPosted: Fri Jun 22, 2007 7:09 pm
I refuse to answer this thread due to the fact it will depress me when I realise how far I have to go with the fang :(
PostPosted: Fri Jun 22, 2007 8:23 pm
I agree Ian....but
Daily drive needs to be retuned and put on the dyno to hit 50
Poor Marcia..Back end is finished some time ago.
But suspention, Brakes, Motor, Box...basicly everything up front
ow..and the Dash Seats and the back of the van...hmmm
And also to mention I want to change the colour :twisted:
So ner
PostPosted: Fri Jun 22, 2007 11:15 pm
76 Clubby:
Busted 998 (threw Circlip on N#3 killing bore and smashing valve)
Rust in most panels
spare will drop through the floor and day now
worst repair job done on front end (100kgs of bog not me)
crappy paint job (2 tone yellow)
shot CVs
busted radiator
interior a joke.
but it's mine.....
PostPosted: Fri Jun 22, 2007 11:19 pm
OK ....
Sports850 ,
interior needs a good clean and touch up , exterior a deep clean and polish . Tune up wouldn't go astray either and it NEEDS club plates for some fun
Moke ,
Needs rego basically , it's all good . drivers seat a little tatty but that's it .
Van ,
Motor painted and put back in , engine bay painted , roll cage put in , interior tidied/finish fitting and club plates .
Fang ,
Brakes , electrics , interior , exterior , time ........
Users browsing this forum: Bing [Bot] and 88 guests
