It is currently Mon Jul 28, 2025 12:59 am
 Post subject: POP AND CRUNCH
PostPosted: Fri Jun 22, 2007 5:03 pm
Location: Woodside, Hahndorf and Mount Barker South Australia
second gear pops out when coasting and slowing what is it and whats involved and she crunches when you go 1st to 2nd and 3rd to 2nd......
people say keep ya friends close and you enemies closer BAH I say keep your friends close and your enemies at maximum effective range.
PostPosted: Fri Jun 22, 2007 5:06 pm
synchomesh is worn, pretty common in second gear
PostPosted: Fri Jun 22, 2007 5:08 pm
lots of mini gearboxes wear out the synchro on 2nd, why only second????
my old one was a real (want to swear but shouldnt...) when it came to the crunch, if its serious you may want to look at getting it reco'd
78 Leyland Mini - Prince
PostPosted: Fri Jun 22, 2007 5:09 pm
how involved and........expensive is that??????
PostPosted: Fri Jun 22, 2007 5:20 pm
mixed bag really, its like lifting up vinyl flooring, you could discover alot worse stuff that needs fixing, PITA is you've got to seperate the box from the block, and while your there....etc etc its a good time to do stuff right.
sorry cant help you on price, everybody has diff rates. luckily i have a friend who does it for around $200, plus parts and guiness.
PostPosted: Fri Jun 22, 2007 6:33 pm
Like the K said, bit of a Pandora's Box (bad pun) :twisted:
The synchro rings are about $30-$40 each - need 4, plus the layshaft & bearings will inevitably be worn. Then you need to check 1st motion, spiggot & main centre bearings so it soon adds up. Obviously you can reduce labour costs by removing/repalcing it yourself but even then your'e probably up for about $700 for a decent recon. :cry:
PostPosted: Fri Jun 22, 2007 6:43 pm
Or you can put up with it till it's really bad , I drove one like that for over 20,000 k's , just go slowly on the downshift and when it get's worse double clutch it into 2nd . It'll teach you how to be kinder to the gearbox as well , mini gearboxes don't like snap changes into 2nd .
PostPosted: Fri Jun 22, 2007 8:35 pm
I'd agree - you don't have to rush into fixing the box. Yes, what's been described is a fault and needs fixing, and it will get worse but, if you can live with it you'll have the opportunity to learn a bit more about your car, and how to treat it well. Treated kindly, you can keep going for a fair bit. :)
And the reasons why second's synchro is the one that generally goes first are that second gets used a lot - probably more than any other gear - and there is a decent speed difference that the synchro needs to overcome. In other words, the higher the ratio, the harder the synchro has to work. Fourth is generally a 1:1 ratio, so it's not hard for the synchro to speed up the gears, where 2nd is usually more like 1:1.8 (roughly), so the synchro's got to work about 1.8 times as hard, because it's got to make the input shaft spin 1.8 times faster for second than for fourth at a given speed. :wink:
 Post subject: Oil
PostPosted: Fri Jun 22, 2007 8:43 pm
Keep the oil changes coming, regularly clean the magnetic particle attraction rod on the sump plug and maybe think about adding rare-earth magnets to your oil filter to (hopefullly) extend the life of the box before maintenance :idea:
PostPosted: Fri Jun 22, 2007 8:45 pm
Forum Graffiti
My old mini's g/box had the exact same prob... :evil: there was no chance in hell of changing down from 3rd to 2nd, and If you tryed to accelerate in 2nd.. POP!! When you know how to double clutch, its soo much more fun... being able to downshift into 2nd around the corners instead of put-ing around in 3rd :) he he. Not many people could drive my car, 'cept me and my dad... :wink:
 Post subject: Re: Oil
PostPosted: Fri Jun 22, 2007 8:49 pm
rare-earth magnets..................
PostPosted: Fri Jun 22, 2007 9:14 pm
Yeah...rare-earth magnets, powerful, focussed magnets that pull out all the magnetic particles shed by the complaining synchro rings....clean oil IS the best mechanic :idea:
PostPosted: Fri Jun 22, 2007 9:15 pm
where do i get them from??????????
 Post subject: Gaf
PostPosted: Fri Jun 22, 2007 9:17 pm
Gafmo??? or search on magnets.....and attach them to your oil filter :!:
PostPosted: Fri Jun 22, 2007 9:27 pm
Know of anyone with a dead hard drive in their puta? These magnets can be ripped out of one of them and then tapped to oil filter.
If in doubt ask
