It is currently Sun Jul 27, 2025 10:07 pm
 Post subject: Alarm & Central Locking
PostPosted: Wed Jun 27, 2007 10:18 pm
Hi there,
I am just wondering if you can buy any type of alarm and it will fit a mini and also if you can get central locking? Also, what brand is good value for money?
I want to add to the security of my car other than the immobiliser I have.
Thanks,
PostPosted: Wed Jun 27, 2007 10:24 pm
Slow-Po
Any type of alarm will be ok as long as you have room to fit it. As for central locking, and few people have tried it (the majority on here prefer to lift their left arm :wink: :) ), do a search and you should find some info. 8)
PostPosted: Wed Jun 27, 2007 10:53 pm
I have an alarm with central locking kit suit a Rover Mini...
maybe with some modification you could get it to fit and work properly
Miniworx Centre 0883741299
Online BMW Mini Shop
PostPosted: Thu Jun 28, 2007 10:01 am
I did this recently and the guys pretty close to you. Bit pricey though
1972 Clubman needs full resto
Coming soon: www.pimpthemini.com
PostPosted: Thu Jun 28, 2007 10:51 am
I want to have Al's babies
I've got an alarm and imobiliser in the BOC - required for insurance. Couldn't be f'd doing the central locking, tho. ;)
PostPosted: Thu Jun 28, 2007 11:26 am
Can you PM me the details please? :)
PostPosted: Thu Jun 28, 2007 1:33 pm
is your a round nose ?? cause i don;t think you can put central locking in it unless yours a leyland
1967 Morris Mini Minor - 1380 cc 45mm weber, leather interior, MP3 player with 4' Kicker spits alpine 6x9 and 10in JL sub and Kicker 4 channel amp.
PostPosted: Thu Jun 28, 2007 7:01 pm
i have a pageguard alarm system with central locking. central locking in my leyland mini took a lot of modifing but i was able to make it work perfectly.
PostPosted: Thu Jun 28, 2007 7:06 pm
I know the guys in Lifestyle Store at Parramatta can do the central locking in any of the mini's, they have to make certain parts for it to work. And i'm guessing for that they will charge a bit but hey they would do a professional job.
PostPosted: Thu Jun 28, 2007 8:41 pm
Are you able to pm me the details of who did it for you and a guide as to how much it costs.
Thanks
PostPosted: Thu Jun 28, 2007 9:10 pm
i did the modifing myself.
PostPosted: Fri Jun 29, 2007 8:06 pm
I've fitted central locking to one of my clubbies (with lift up handles). Not too difficult if you've got a mind for it and the ability to make little brackets etc...
I've looked at putting it into one of the roundies I've had (with the 'twisty' handles) and the only way it could be done would be to make up your own lock assembly and work out some way of concealing it and fitting it to the doors...
PostPosted: Sat Jun 30, 2007 1:55 am
Ive seen central locking done on a roundy with early doors...... the actuator simply pushed a 10mm steel pin from inside the door thru a hole in the B pillar under the regular catch - kinda like the locks you would find on most new car fuel flaps.
All it needs to do is stop the handle from being pushed down.....
PostPosted: Sat Jun 30, 2007 3:24 pm
Try using solinoid operated shotbolts that go into the B-pillar from the door??
I know it sounds silly, but someone told me about it, that they'd seen it done on a mini :shock: ....Can't remember who said that though.
I was going to do it to the clubby, got the actuators cheap, but they were a bit big to fit in the doors, but anytings possible, for a roundnose, as said above, it's possible, but I don't think it's practical, but clubby/rover, go for it!
PostPosted: Sat Jun 30, 2007 7:54 pm
I might have mentioned it at Minis At The Bay...
Users browsing this forum: fuzzy-hair-man and 81 guests
