What he said, ^^^ generally.
However
the Dellorto has a greater range of jets than the Weber, not that you need to use them all.
The mains for example go up in steps of 1- eg.
180, 181, 182 etc.
Method of operation and appearance of most parts like jets and chokes is similar, but of course, nothing is interchangeable...
Bolt spacing front and rear is same as a Weber, so they use the same air filter and manifold.
Weber are easier to get parts for here, but I buy all Dellorto bits I need from
www.dellorto.co.uk as it's easier and cheaper.
I've run a 45 Dellorto for 14 years, had no problems with it. As far as power compared to Weber goes- for a street car there's nothing in it.
Currently it lives on my 1360, with 38mm chokes and an RE282 cam it pulls hard from 3000-8000 rpm.
On MRC dyno, day it outran a few Webers......
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
