It is currently Fri Jul 25, 2025 11:57 pm
How would you paint the engine?
Paint individual components then assemble? 52%  52%  [ 12 ]
Paint individual components, assemble then give another coat to finished engine? 13%  13%  [ 3 ]
Assemble the engine first then paint it? 35%  35%  [ 8 ]
Total votes : 23
 Post subject: Painting the Engine
PostPosted: Fri Jun 29, 2007 12:38 pm
What is the best way to paint your engine?
David L
PostPosted: Fri Jun 29, 2007 12:51 pm
paint the box, then block and head together, followed by the other stuff
PostPosted: Fri Jun 29, 2007 1:24 pm
but obvioulsy (and i reckon you would know this, you're no fool!) make sure you dont get paint on any of the faces or on any interior part
78 Leyland Mini - Prince
PostPosted: Fri Jun 29, 2007 4:10 pm
Give Ash some flowers Nick .
For me if I had the engine out I would definitely paint all the parts individually BUT if it were already in and assembled you would only have to paint the bits that you would see and there is no chance to scuff up your new paint during assembly.
PostPosted: Fri Jun 29, 2007 4:15 pm
Depends on what look you are after. For the real OEM style look it has to be paint individual parts.
If you are in a rush or the above is not possible, I've seen some good looking whole engines painted before.
Personally I like to see gaskets and seals, gasket and seal colour :wink:
Lillee - 1969 Morris Mini K
PostPosted: Fri Jun 29, 2007 4:25 pm
if you paint the engine whole will it make it difficult to separate some parts? cos they have a coat of paint over them?
PostPosted: Fri Jun 29, 2007 4:43 pm
Not unless you paint it too thick. :)
On a rebuild I tend to paint the block fully assembled sitting on a Morris Minor sump.
If it's a quick tidy up and the gearbox is not coming off I paint the lot.
Either way I block off the dizzy hole with a rubber plug and the intake/exhaust flange with an old gasket wrapped in masking tape to cover the ports.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Jun 29, 2007 5:48 pm
dont paint the box :x
its alloy, wont rust and will get rid of heat better without paint on it..
not to mention it chips off..
PostPosted: Fri Jun 29, 2007 7:28 pm
Paint the timing cover seperately because the harmonic balancer will be in the way if fully assembled. Also paint the inner face of the harmonic balancer before you put it on.
Paint the head, block and gear box all at once with an old rocker cover on it. Paint the rocker cover seperately and do a really good job of it as it is the most visible.
Dont forget to mask up where the speedo cable screws onto the gear box :wink:
Make sure you post pics when it is painted :D
Matt
PostPosted: Fri Jun 29, 2007 7:34 pm
Actually chong, if your after an OEM look for a roundy, it would be first painted BMC green(the dark one) then Painted Australian Metallic Green(the light one) all assembled of course. all motor's were originally shipped to aus as crate motor's at fiest then were painted australian metallic green when they got here. This of course changed as the motor's were built over here.
:wink:
Aaron
PostPosted: Fri Jun 29, 2007 8:05 pm
BMC just painted the whole shebang assembled, minus a few external bits... on the assembly line- that was their OEM method.
No prepainting for them. That takes time! :lol:
Last edited by drmini in aust on Fri Jun 29, 2007 8:59 pm, edited 1 time in total.
PostPosted: Fri Jun 29, 2007 8:56 pm
Dont forget to tape up your vee belt grooves. Painting them assembled means you dont have to touch up the bolt heads, otherwise poke your bolts through a piece of cardboard so you dont do the threads.
Michael N
PostPosted: Fri Jun 29, 2007 10:34 pm
Like this...and don't paint the oil filter housing or the thermostat housing
 Post subject: hi
PostPosted: Sat Jun 30, 2007 9:41 am
use paint :lol:
PostPosted: Sat Jun 30, 2007 9:48 am
After screwing around with spray cans I want to try brush next time - can't seem to find a brush engine paint though...
Edit - interesting seeing welch plugs painted...I like 'em brassy
