It is currently Wed Jul 30, 2025 2:08 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jun 30, 2007 1:07 am
Just because the car runs badly I wouldn't assume it needs a rebuild. I don't know what your mechanic was thinking.
The things you should look for a signs of needing a rebuild
Low oil pressure - could be worn bearings
Blowing blue smoke - usually rings
Fuming badly from breather - usually worn rings (can be head gasket though)
If it's not doing any of these things then it unlikely it needs rebuilding
I'd be checking all the things that have been mentioned previously
Vacuum leak is a very common malady that makes a car run like a dog.
For checking the tune of the carb. Single SU's are very simple. Check this site
http://www.moreg.org.au/carburettors.htm
Keep us posted on your progress, I'm sure the combined knowledge of this forum should be able to get it on track.
Pete
PostPosted: Sat Jun 30, 2007 11:05 am
yea we know darryl hes a good bloke he doesnt know whats wrong with it either, he was even guessing
 Post subject: Hour
PostPosted: Sat Jun 30, 2007 3:11 pm
The only other bloke I can think of beside Warwick is an hour away near Kingsvale......It might be worthwhile grabbing a trailer and taking it to Tim at the Olde School Garage in Wagga :idea:
Or
The fella who runs the mower shop in Young used to work in the BMC dealer and knows Minis...and across the road and back is a little engineering shop...that fella has some knowledge.
PostPosted: Sat Jun 30, 2007 3:22 pm
theres no air leaks darrel a mini mate and i spent hours doing ever thing including praying for it to get it at least running I even said to my son to reg the mark 1 iv got sitting in the drive way
Cowras a little town very few know about the mighty mini except in there dreams
Looks like the clubby stays off the road till we work out a better idea of whats upsetting her
maybe i will get a chance to clear my drive way of a few mins that need to be on the road anyway
THANKS FOR YOUR IDEAS :lol: :lol: FALLAS
IM LITTLE BUT I HAVE A BIG DONK
PostPosted: Sat Jun 30, 2007 3:25 pm
YEP YOUNGS only a little way might seek some help that way
thanks cobber
 Post subject: Distributor out??
PostPosted: Sat Jun 30, 2007 3:52 pm
Smokey wrote:
YEP YOUNGS only a little way might seek some help that way thanks cobber
The other thing would be to ask the Mech if he had the distributor out...they can be put back in 180 degrees out :idea:
The mower place I mean in Young is up near the railway crossing and the street runs parallel to the line...off the Cowra Rd.
PostPosted: Sat Jun 30, 2007 7:58 pm
found the dist got a bit of play just maybe it could be the problem
THIS COULD THE PROBLEM
Why didnt this mechanic tell me this instead of rebuilding it TRULY NEVER WILL I TAKE ANY THING TO HIM AGAIN
