It is currently Sat Aug 02, 2025 9:56 pm
 Post subject: seat belt blue slip
PostPosted: Sat Jun 30, 2007 7:16 pm
Sorry for bugging you fallas im knew to this iv left the clubby till i think of a few other ideas Iv built a mini k from an empty shell My blue slip falla said he wouldnt pass my my little girl because she carryed seat belts in the back So upset i went home fumeing
Did they ever com out with belts in the back my son said they had the option to hav them Any of you fallas heard any thng like this
IM LITTLE BUT I HAVE A BIG DONK
PostPosted: Sat Jun 30, 2007 7:19 pm
shouldnt have had them if its a mini K but if it did get them put in later (aftermarket) they have to be in there now :wink:
think it was around 72 ish they started puttin rear belts in :wink:
PostPosted: Sat Jun 30, 2007 7:27 pm
Okay thanks mate
could i get bust after she passes by puting them back in for the kids
PostPosted: Sat Jun 30, 2007 7:29 pm
Take the rear belts and any plates that were added when (and if) rear belt mounts were installed and go to a different guy. They can't fail you on rear belts in a roundnose as these were never standard. I have a 1970 mini K with no rear belts and I pass rego every time and had the car re-registered just recently with no probs.
PostPosted: Sat Jun 30, 2007 7:30 pm
i dont think they would do u for puttin them in after u get inspected :wink:
 Post subject: Arguements....
PostPosted: Sat Jun 30, 2007 8:58 pm
If someone has put them in in the past (reasonably common)...then the inspectors would just think there is provision for them and say they should be there.
Whether they were installed by a do-it-your-selfer or a garage don't matter....you have to either convince the guys that they are not standard or get them fitted and inspected by an authorised fitting station and be done with it.
In a small town there ain't gunna be too many options :!:
If you do your homework and approach them again you might get away with it :idea: good luck.
 Post subject: Re: Arguements....
PostPosted: Sun Jul 01, 2007 7:16 am
9YaTaH wrote:
If someone has put them in in the past (reasonably common)...then the inspectors would just think there is provision for them and so they should be there.
Why not just remove them? No rego inspector checks under your rear seat for evidence of seat belt mounts.
PostPosted: Mon Jul 02, 2007 12:23 am
but i think the original problem was that the belts werent there at all?
to be honest, i dont see why you can't have them there, all arguments aside. especially if you are going to have your kids in there. you may not need them for rego, but what harm does it do getitng them installed?
my 2c
78 Leyland Mini - Prince
PostPosted: Mon Jul 02, 2007 2:11 am
the big question is... why is this thread titled "Brakes"?
PostPosted: Mon Jul 02, 2007 2:33 am
bloody good question Cush!
Noli Illegitimi Carborundum
PostPosted: Mon Jul 02, 2007 9:50 am
I want to have Al's babies
Sorted. 8)
PostPosted: Mon Jul 02, 2007 10:49 am
Remove what?? Smokey is saying they were never fitted.
I was saying, IF someone had fitted belts in the rear of a K..then this is what might happen or what you might do.
I strongly recommend to Smokey that he "does his homework" and goes back to them to argue the toss....the inspectors have a book that they go by, if it is written in the book the Ks had rear seat belts (more likely that Minis had them from a certain date).....well, you have to convince them they are wrong (in the nicest possible way, or elevate it up their chain of command).
PostPosted: Mon Jul 02, 2007 11:58 am
My Mini is dated 3/70, no seat belt anchors for rear passengers it it.
I don't carry people back there. it reduces the power/weight ratio. 8)
PostPosted: Mon Jul 02, 2007 3:06 pm
my 1970 mini k has rear seatbelts, and they look factory fitted
PostPosted: Mon Jul 02, 2007 7:15 pm
Rear belts were an option from at least 65. They also were sold as accessories and you could pay the dealer to fit them.
HYH2693 - Safety Belt (rear seat)
Retail price £4.10.0 - $9.00
Installed price £5.10.0 - $11.00
This would have been just a lap belt. Lap/Sash belts are also listed.
