It is currently Fri Jul 18, 2025 9:40 am
 Post subject: Missing engine
PostPosted: Sat Dec 18, 2004 7:08 pm
My mini has developed a mis all of a sudden. It appears to be running only on cylinders 1 &4. There seems to be spark coming from all 4 plugs yet when i pull the leads off cylinders 2 &3 the engine makes no change, unlike 1 &4 which nearly make the motor stall when i disconect them. (thats what makes me think its cylinder 2 & 3 thats not working. Any ideas whats happened? Could i have a blown head gasket between 2-3 causing the spark to blow out?
PostPosted: Sat Dec 18, 2004 7:17 pm
Yep youv'e done a head gasket.
 Post subject: ouch!
PostPosted: Sat Dec 18, 2004 7:19 pm
Certainly sounds like it ....unless the points/dissy cap, spark plugs or Ignition Leads to 2 and 3 are absolute crap! :(
PostPosted: Sun Dec 19, 2004 6:37 am
Do a `bush compression test'- remove plugs, put your thumb over each plughole in turn while someone cranks the starter. :wink:
If gasket is blown, it will be obvious- :lol:
PostPosted: Sun Dec 19, 2004 9:27 am
thanks for that. Hey kev, i tried the bush test, but they all seem to have compression,ie they all force air past your thumb. However, does it only work if u have all the plugs out at the same time? i just took 1 out at a time. Should that make a diff? I can't seem to find anything else that may be causing it. Maybe i'll have to take the head off.
PostPosted: Sun Dec 19, 2004 9:35 am
If they all feel the same gasket is OK. Usually when it's blown there's F'all compression in 2 adjacent cylinders.
Are these 2 plugs wet?
PostPosted: Sun Dec 19, 2004 9:39 am
I would go and change all the ignition stuff, thats the first thing I do when a problem like this occurs. Change the points, condensor and plugs. Check the leads (shouldn't have much resistance) and do so when they are attached to the dizzy cap (so you know the connection between the cap and the leads are fine).
PostPosted: Sun Dec 19, 2004 9:43 am
only number 3 looked a bit wet, not 2.
PostPosted: Sun Dec 19, 2004 9:46 am
Maybe take the rocker cover off and adjust all the tappets?
PostPosted: Sun Dec 19, 2004 9:50 am
ok. i'll have a go tomorrow when the shops are open. could be an excuse to get the head done up lol. It has pretty high compression anyway so changing the head gasket might still be a good idea.
PostPosted: Sun Dec 19, 2004 9:51 am
Before you do anything else, I'd put 2 new plugs in there. :wink:
PostPosted: Sun Dec 19, 2004 10:05 am
Cheers doc! all going! weird cause the plugs were giving spark when i checked them, maybe just not at the right time or something.
PostPosted: Sun Dec 19, 2004 10:10 am
It takes more volts to fire a plug in a cylinder with fuel mix under pressure than it does out in fresh air.
Cheers, Merry Xmas!
PostPosted: Sun Dec 19, 2004 3:00 pm
1. Fill the radiator to the brim and see if bubbles come out.
2. Any condensation under the oil filler cap?
3. The best and quickest way is to find a gas analyser and stick it in the neck of the radiator. If it registers mixture then there is a compression leak to the cooling system.
4. Swap the plugs from the cylinders firing to those that aren't.
Chris
Everything I like is either
Users browsing this forum: Bing [Bot] and 82 guests
