It is currently Wed Jul 02, 2025 4:32 am
 Post subject: Rear Wheel alignment
PostPosted: Sun Jul 01, 2007 8:36 pm
Are rear wheel alignments able to be done on mini rear suspension. Have a 05 cooper S that is is scrubbing the inside of the left rear tyre. has been to bob janefor a full 4 wheel alignment but have noticed it is still scrubbing. i looked under rear of car and it looks like there is no adjustment. did they charge me for looking and done nothing or can adjustments be done? Any one out there who know more about the rear suspension?
harri
PostPosted: Sun Jul 01, 2007 10:39 pm
i think they do have adjustable rear on them.
You wont know any difference because it takes a tire a while to wear down,
if you get new tires and get the wheel alignment done it is a much better chance it will probabbly work the first time and hopefully you wont have to go back and get it fixed up again
PostPosted: Mon Jul 02, 2007 6:12 am
Yeah right. I got the wheel alignment when i got new tyres fitted. have noticed since then it has started wearing the tyres the same as it was before. thanks
harri
PostPosted: Tue Sep 25, 2007 11:16 pm
No.... not adjustable from factory.... if it is scrubbing then it will always until you buy the aftermarket adjustable arms.
Front is the same.. only the toe in/out can be adjusted, everything else can't.... :shock:
I was told by the BMW dealership that they are made by BMW and don't need adjusting... perfect from the factory.
Freinds MINI pulls really badly to the left..... " Must have hit a gutter or something" ....As if!!
Adjustable is the way to go... will cost you though :oops:
Minimad
Ps Don't forget to thank BJ for taking your money and "forgetting" to tell you that it isn't adjustable!
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Tue Oct 02, 2007 8:44 pm
Thanks,
was told by the dealer the car came from new that the rear was at the end of its 'adjustment'. I stuck my head underneath and could not see any way of adjusting it. I called another mini dealer to be also told that they can be adjusted. Our mini did hit a kerb so we have a problem.
happy driving. :arrow:
harri
