It is currently Sat Aug 16, 2025 2:11 pm
 Post subject: Driveshafts
PostPosted: Mon Jul 02, 2007 8:28 pm
I thought the drive shafts between drum & disc are the same.
see this ad
http://cgi.ebay.com.au/Mini-Morris-1275 ... dZViewItem[url][/url]
 Post subject: drive shafts
PostPosted: Tue Jul 03, 2007 7:30 pm
they are the same put disc brakes on my mini used drum shafts you only change flange
 Post subject: Re: drive shafts
PostPosted: Tue Jul 03, 2007 7:43 pm
When I converted my original '78 Clubman from Drums to disk, I had to use the Disk Brake CV Joints. They were larger on the splines etc. Used the Clubman shafts with inner Pot Joints etc, and used Disk Brake outer CV's.
PostPosted: Wed Jul 04, 2007 7:44 am
i thought the drum brake drive shafts were slightly longer, but splines the same as disc items.
But you can get away with not worrying about it?
Users browsing this forum: No registered users and 70 guests
