It is currently Thu Aug 07, 2025 12:50 am
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Thu Jul 05, 2007 6:36 pm
I just thought I would show the latest modifications to my hydro pump.
PostPosted: Thu Jul 05, 2007 7:35 pm
Well Morris 1100, it's good to see somebody else use the same setup as me. The only difference is that I use the bleed type schraeder valve. Cost me $43 way back in 1977 and still going strong.
PostPosted: Thu Jul 05, 2007 7:45 pm
Looks pretty much like mine really-
The base is a Fiat 124S pedal box.
The end fitting I made from a Schrader brass valve cap, machined then gas soldered into a brass fitting. The rest is 2 Mini front hoses and a bit of brake pipe.
Cost me $0.00 to make 12 years ago, had 1 seal kit and 2 hoses since, still works. Good value.8)
Next mod one day will be a Clubby MC with the plastic reservoir.
PostPosted: Thu Jul 05, 2007 7:58 pm
Aim for a bigger reservoir Kev. I used the Clubby but still didn't hold enough fluid if doing a fresh pump up. I've yet to heed my own recommendations, another of those "I'll get round to it" jobs.
