It is currently Sun Jul 27, 2025 9:41 am
PostPosted: Fri Jul 06, 2007 10:31 pm
Are these the same part?
With the 1330 in my clubby and the standard radiator which support should I be using?
I bought a Gt one from Mini King last sunday but it is too short from the thermo housing to the top mounting holes on the radiator.
Are the 1275 Ls ones different again?
Any pics would be great if possible :wink:
PostPosted: Fri Jul 06, 2007 10:48 pm
Pretty sure the GT one is longer than S, the LS is different again as it had the air pump fitted, and the top hose going back to near rad cap.
PostPosted: Fri Jul 06, 2007 11:50 pm
here's are pic of LS type with rear facing top hose.
PostPosted: Sat Jul 07, 2007 4:33 pm
Well I can cancel out the LS one :o
PostPosted: Sat Jul 07, 2007 8:42 pm
The Mini King
Hi Gilly, bring the one you bought back to me at mini king and we will make sure you get the one you need
Regards
John Smidt
PostPosted: Sat Jul 07, 2007 10:03 pm
Clubman GT top radiator support bracket original part number is: AYG2248 and looks like this....
Kev is right, it would be wider than a Cooper S top support bracket.
