It is currently Tue Aug 12, 2025 10:24 am
PostPosted: Tue Jul 10, 2007 8:45 pm
hi, i just finished a timing chain conversion, from a single to double, but i'm wanting to check my dizzy timing but i have no marks for the timing on the front pulley. can someone please give me any ideas on how to do my timing without marks.
PostPosted: Tue Jul 10, 2007 8:52 pm
have a look on the flywheel.
There is a little flap on the housing that you will see the timing marks. Use a torch and a mirror to see 'em.
PostPosted: Tue Jul 10, 2007 8:53 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
on the other side of the motor there is a little inspection cover on the flywheel cover remove and it is in there
makka
PostPosted: Tue Jul 10, 2007 9:01 pm
ok. i have seen the marks. so how do i time the dizzy
PostPosted: Tue Jul 10, 2007 9:20 pm
using said mirror with a timing light. You will see the timing marks on the flywheel.
Oh and loosen of the dizzy first and try not to move it too much during the process to get the timing right or engine damage can be done.
PostPosted: Tue Jul 10, 2007 9:27 pm
The timing marks are marked a little like thus 1/4....5.....10
and although they need to be read in reverse using a mirror, are not stamped in reverse to make it easy. Be patient and think carefully about what you are after.
PostPosted: Tue Jul 10, 2007 9:35 pm
i think i have seen someone selling a mirror for this reason. it's bent 90deg and it mounts to the two plate bolt holes. i'm trying to find who's selling them.
PostPosted: Wed Jul 11, 2007 8:23 pm
I think this is what you are talking about.
Cheers Pete
http://www.minis.com.au/minis/catalog/p ... cts_id=125
Users browsing this forum: No registered users and 193 guests
